More booooooooooost....?
Old Apr 25, 2003 | 01:14 PM
EVOKILA1's Avatar
Car Info: 03 wrx
Exclamation More booooooooooost....?
if i want more boost into a boxer 4 WRX
first i need to bigger turbo,injentors fuel rails fuel pump......
what about for the engine
?piston?..? valve?.....?rod?...?
Old Apr 26, 2003 | 09:12 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
You can safely get more boost just by opening up your exhaust system. Stock WRX's are in the 13psi range at WOT. But after doing an uppipe and downpipe you should be at around 14.5-15psi with spikes to 16 possibly.
But if you want more "booooost" Just raise the boost to 15psi with a boost controller.
Old Apr 26, 2003 | 11:29 PM
EVOKILA1's Avatar
Car Info: 03 wrx
see if theres someone make a 300-400 whp wrx
what they will do
Old Apr 26, 2003 | 11:55 PM
teiva-boy's Avatar
what they will do
Well in that case, you can do it with bolt-ons and never have a need to tear into the engine itself. 300-400HP is easy. With a Vishnu Stage 1 or TurboXS Stage 2-3 you should be at or around 300HP already.
Old Apr 27, 2003 | 01:38 AM
EVOKILA1's Avatar
Car Info: 03 wrx
with stage 1 i dun think it provide 300 wheel horse power
it doesn't enough to me
i really want do some engine work before put a big turbo
what brand or type of piston ,piston ring ,rod
u all perfer for wrx .?
Old Apr 27, 2003 | 01:02 PM
teiva-boy's Avatar
You never specifically WHP, only HP.
04caliwrx
116
Jan 12, 2012 03:36 PM
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
Kostamojen
May 18, 2003 11:46 PM
EVOKILA1
Apr 26, 2003 12:30 PM
MPOWERD
Mar 19, 2003 08:23 PM
