booooooooooost
Old Apr 24, 2003 | 09:22 PM
EVOKILA1's Avatar
Car Info: 03 wrx
Exclamation booooooooooost
how many psi do u guys think
that wrx stock motor can take .?.?
Old Apr 24, 2003 | 11:29 PM
mario's Avatar
it all depends on the turbo your running i think but beware!
Old Apr 25, 2003 | 09:23 AM
WRB_WRX's Avatar
Car Info: 03 WRB Sedan
Remember, stock fuel cut is at 18 PSI. The stock turbo can make 16 to 17 PSI peak, but as the RPM picks up, so does flow into the engine, boost it will settle back down to around 14 PSI as the turbo is maxed out on capacity. If you want more at the top end try an Ion-Spec turbo, it will hold 17 PSI to red line, with no more lag than you have with a stock turbo! Just be sure to have your UTEC tuned properly when you do!
Karl
Old Apr 25, 2003 | 10:47 PM
Advancetekwrx's Avatar
Car Info: 02 PSM WRX V8 STI/Green powered
im at 20psi, daily driven on my vf34..and have spiked to 23psi
EVOKILA1
Apr 28, 2003 02:50 AM
