Miss fire ....
Old Sep 29, 2012 | 09:18 PM
wrxmo's Avatar
Miss fire ....
Okay so I had a miss fire in cylinder one two and three . I changed the plugs and only cylinder one came back so I changed the coil pack . It came back . I changed the exaust temp sensor because that was causing other Sensors to mess up such as circuit high and low in the maff and exaust temp sensor . So cylinder one was still messed up so I just changed the injector . Not the chec
Old Sep 29, 2012 | 09:20 PM
wrxmo's Avatar
The check engine light is flashing and the engine is running like compleate Sh** and there's a squeeking coming from the engine an three is no power what so ever
Old Sep 29, 2012 | 11:04 PM
johndabrit's Avatar
Da Brit.
Squeaking can mean boost leak.
Old Oct 3, 2012 | 02:02 AM
JASC's Avatar
Car Info: 2003 WRX
Well if you checked and changed the spark components (spark plugs, coil pack) and you replaced an injector than what about the rest of the fuel system? i had a faulty fuel pump that gave me a misfire on 2 cylinders. Also, have you checked your fuel filter? From what you describe as "my motor runs like crap" than it could very well be the filter or pump. The squeeking problem could be a number of things.
Old Oct 5, 2012 | 10:45 AM
wrxmo's Avatar
Okay so I changed the injector and seeded it properly and that squeeking when away and it ran fine for a couple hours then cylinder one misfire came back I'm Gona swap the coil pack from one to three and see if the miss fire moves but if not fuel pump ?
Old Oct 9, 2012 | 03:24 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Valve clearances. Check them.
Old Oct 9, 2012 | 11:13 PM
Sean Zahra's Avatar
Car Info: MAD STI
I had the same sh**, it took me so long to know what's with it, I had three misfire 1,2, and 3, I couldn't know even my mechanic didn't know, so I took it to the dealer, and they said its the head casket, so when we took the engine out to replace the casket kit, my mechanic realized that it's the timing belt!!! It needed an adjustment! So you might wanna check that.
SomeDudeD
Nov 7, 2012 08:59 AM
ej20_wagn
15
Mar 16, 2010 04:20 PM
redwrx
Jun 6, 2003 09:13 AM
IS2Scooby
Jun 1, 2003 07:09 PM
PsycloneWRX
Dec 10, 2002 10:29 AM
Top
