Max boost for 2005 WRX
Old Jun 4, 2013 | 11:26 PM
Qazyip's Avatar
Car Info: 2005 WRX BLACK
Hi, I am considering to get one of the boost controller for my 2005 WRX. I would like to know that what is the max boost I should push that is safe for my turno? I am running stock engine and turbo thou. Thanks for help!!
Old Jun 5, 2013 | 05:08 AM
Brfatal's Avatar
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
Wrong section - Moved to Engine/Power - EJ20T.
If you have to ask this question, then a boost controller is not for you. Bugeyes were ok to use boost controllers untuned IF you knew exactly what you were doing. Later models were much more finicky. Your car is not a DSM. You can't simply turn up the boost without adding fuel.
Old Jun 5, 2013 | 03:18 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Correct... You can to tune the car with the boost controller to run it safely. Otherwise you will run a high risk of engine damage.
-- Ed
John OBrien
Engine and Drivetrain
May 7, 2009 10:03 AM
arden
Apr 13, 2004 03:22 AM
SloshSparky
Jan 25, 2004 11:53 AM
Hassassin
Nov 26, 2002 01:04 PM
Hassassin
Nov 26, 2002 11:09 AM
Top
