Loss of psi?
Old May 15, 2010 | 12:43 PM
rikakidd's Avatar
Car Info: WRX Bugeye
Loss of psi?
hey guys well im new to i-Club but i do not have an Sti so i hope i dont get scorned just a young kidd trying to get some help.
well i have a
03 mbp wrx
blouch evo3 16g
greddy fmic
injen CAI
APS downpipe
Cobb CAtback
and recnetly had an Agency Power bov whic i had to somewhatrepair my self and had it on but it was sort of leaking so i took it off and put the stock one back on.
well mty problem is that i used to get to 21 psi around 6300 rpms and it would go all the way to 6700 and on, but recently my car has barely been making it to 15 psi?
what coyuld this be?
i have searched around and i have read about boost leak?
but i am not sure and im on a tight buidget being a 18 going to school full time and barely working so if there are some tips you guys can give me to check out so iwont have to take it to a shop and be charged a bunch load of money.
thanks rika
and im int the 209 area so if anyone can hit me up please and thanks
Old May 15, 2010 | 12:47 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Is the car tuned? What are you using for boost control? You can try resetting the ECU.
-- Ed
Old May 15, 2010 | 01:32 PM
rikakidd's Avatar
yes the car is tuned it was tuned by the previous owner in the OC,
and as far as MBC i am not positive if i have one X[
like i said im a noob sorry Ed,
where would i be able to find the MBC?
ye maybe i will reset the ecu, lemme try that. =]
Old May 15, 2010 | 06:15 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
There are a lot of places to install an MBC. Generally it would be by the passenger side strut tower.
-- Ed
Old May 16, 2010 | 12:06 AM
rikakidd's Avatar
Well it doesnt have an mbc but it does habe apridruve electronic boost controlly which is not adjustable, so im leaning more towards a boost leak because i also reset the ecu and nothing. It has an open source tune on the stock ecu
when the car is cold and i turn it on tere is a loud hissing noise maybe coming from a loose coupling?
Or from the inlet?
Old May 16, 2010 | 03:27 AM
WRX409's Avatar
Car Info: 04 WRX
Possible exhaust leak or boost leak?
Old May 16, 2010 | 11:04 AM
rikakidd's Avatar
So it could also be an exhaust leak?
Old May 16, 2010 | 11:14 AM
subie_roo's Avatar
Car Info: 2005 Forester 2.5X
The stock BOV will not hold up to 21 psi. It's designed for much lower pressures...
Old May 16, 2010 | 03:07 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
The stock recirc valve will hold 21psi.
For how long, now that's he question.
Old May 16, 2010 | 03:37 PM
WRX409's Avatar
Car Info: 04 WRX
In his case upgrading the stock recirc valve is a no brainer.
Old May 16, 2010 | 09:07 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Modifying the stock BPV is also a good option
-- Ed
Old May 17, 2010 | 02:34 AM
WRX409's Avatar
Car Info: 04 WRX
-- Ed
True that.
Old May 17, 2010 | 03:26 AM
rikakidd's Avatar
Is BPV and BOV the same thing?
Well i mean i never had this problem with eiter the stock bov nor the AP one neither?
Old May 17, 2010 | 12:35 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
A BPV is plumbed back into the intake so that it returns the blow-off air back to the intake. A BOV is generally venter to atmosphere.
-- Ed
Old May 17, 2010 | 01:46 PM
rikakidd's Avatar
Oh ok then i will get to you guys as soon as i am off wirk and have enough time to check out the fmic couplers the uppipe and bpv and etc. Thanks again
subawagon
Jan 18, 2005 11:10 AM
mmboost
Jan 9, 2004 11:25 PM
rednek wrx
26
Mar 14, 2003 01:38 PM
wrx137
Dec 16, 2002 08:08 AM
schwarzenegger
Dec 3, 2002 01:33 AM
Top
