leaking water??
Old Aug 21, 2005 | 01:59 AM
1neWRX's Avatar
Car Info: White 04 WRX
leaking water??
Hi i have a 04 WRX and for awhile now it seems i have been leaking what just seems to water. it leaks from the opposite side of the engines liquids, basically teh passenger side. i am not sure what it is or is causing this too happen. do you guys have any ideas? this has not harmed performance of the car, but i am just a little concerned since its been going on for awhile now. thanks
Old Aug 21, 2005 | 02:18 AM
rebbaz's Avatar
Car Info: civic
im not positive, but im pretty sure its from your AC. it has a dump line for the condensed air i think. you know like the AC's on the portables at schools, they drip, same deal.
Old Aug 21, 2005 | 02:15 PM
1neWRX's Avatar
with this from using my AC, because for the most part i dont use my AC
Old Aug 21, 2005 | 04:53 PM
rebbaz's Avatar
Car Info: civic
meh, sorry, but twas my guess.
Old Aug 21, 2005 | 06:42 PM
norcalridin's Avatar
Car Info: 2002 WRB WRX
all it is is condensation from various parts of the engine, most common in the AC... theres no solid water in the engine, if there is waters its mixed with something in it , example, washer fluid!!... anyways, if what is dripping is just water, then there is nothing to worry about because its not comming from inside the engine, just on the outside of the engine itself....
Old Aug 21, 2005 | 10:25 PM
XkrazyAsianX's Avatar
Car Info: SGM 135i
I have the same problem as you, but I have heard that your car can use your AC without your knowledge, mainly when you use the front defroster, the car uses the AC to dry the air. Just my .02 cents
Old Aug 22, 2005 | 02:10 AM
1neWRX's Avatar
mmmhmmm that might be it, i have my front defroster on a lot...almost always...thanks guys
WRXRambo
Dec 18, 2004 12:09 PM
bambams247
Aug 30, 2003 09:08 PM
minisiu
May 22, 2003 10:52 PM
spdkills
Mar 10, 2003 08:31 PM
