Knocking when cold?
Old Dec 15, 2005 | 12:03 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Question Knocking when cold?
So since it's been cold this last month or so, i've noticed what I percieve to be a quiet "Knocking" when I warm up my car in the morning.
I mostly hear it when I'm warming my car up before school. It only happens somewhere between 1000-1700 rpms, when I press on the accelerater, it smoothes out and goes away.
Has anyone else noticed this?
Old Dec 15, 2005 | 02:33 PM
DEMENTEDWRX's Avatar
Car Info: '06 Lexus IS
i kinda get it too
Old Dec 15, 2005 | 06:34 PM
Wingless Wonder's Avatar
Is it an actual 'knocking' sound, or more of a valvetrain clattering sound? Don't rev your engine too much when cold - cold start oil pressure will exceed the pressure relief valve built into the oil filter and go to the bearings unfiltered.
Old Dec 16, 2005 | 12:52 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Maybe it is more of of a clattering, I dunno. So, how long should one let it the car idle until the oil is at the optimum temp.?
Old Dec 16, 2005 | 01:26 PM
meilers's Avatar
Don't idle it, that will just burn gas. Just drive conservatively for the first 2-3 minutes. When your coolant temp gauge is at its normal position (just below halfway up) then your oil is warm enough to give the car some gas.
Old Dec 16, 2005 | 01:34 PM
meilers' is the preferred warm-up method for any vehicle. Driving it easy for the first few minutes puts a light load on the drivetrain and warms up everything from the engine to the tranny to the rear diff, which minimizes warm-up time and wear. Cold-starts cause more wear than almost anything else short of a track day on a road course because of the increased friction when the oil is not yet up to operating temp. The ECU will also initiate a richer mixture on cold-starts which tends to wash the lubricating oil from the cylinder walls.
DsmWRX02
Oct 1, 2004 06:06 PM
KurleeDaddeeWRX
Sep 27, 2003 05:00 PM
jumper
Sep 13, 2003 09:35 AM
FinalBean
Jul 22, 2003 03:39 PM
Fast turbo 20
17
May 8, 2003 11:28 AM
