knocking, because of the uppipe?
Old Nov 14, 2004 | 01:18 AM
imprezilization's Avatar
Car Info: 04 black wrx
Unhappy knocking, because of the uppipe?
just put on my helix uppipe. car sounds great! but it started to detonate around 5000 rpm(w/ full tank of gas). it even threw me a flashing chech engine lite! but it went away. i already had the helix down pipe, cai and greddy evo and worked great before. never heard of anybody getting knocking from bolt on exhaust parts.
makes me worry!
Old Nov 14, 2004 | 12:34 PM
its definitely not the first case, forgot to tell u, i got a cel fix for the second o2.sorri. i dont think its the second case ether, im sure it was detonation, although i would like to learn how to take care off the temp sensor. i think i will take off the cai and see, that might be the problem.
Old Nov 14, 2004 | 04:26 PM
BlkRx's Avatar
Car Info: 2004 Black Wrx
I think that the cai is your problem. It is never a good idea to use a cia in a wrx. If you look around on this board you will see numerous posts which dismiss cia's and go into some in depth discussions about the possible negative reprecusions of using them. It essentially comes down to it leaning out the engine and causing detnoation. I would ditch the cia right away and Id be willing to bet youll be alright. Good luck.
Old Nov 14, 2004 | 11:19 PM
Talking
yep, just took off the cai and went for a testdrive. problems gone. floored in 1st, 2nd and 3rd to redline, no knocking what so ever.
KurleeDaddeeWRX
Sep 27, 2003 05:00 PM
jumper
Sep 13, 2003 09:35 AM
FinalBean
Jul 22, 2003 03:39 PM
Fast turbo 20
17
May 8, 2003 11:28 AM
