JDM EJ20T(STi) v.s. USDM EJ20T(WRX)
Old Oct 23, 2004 | 10:28 PM
awns729's Avatar
Car Info: want a WRX
hmm, well it depends on mroe than redline, but i really dont know.they're botht good choices, the 2.8 liter ispeed short block would probably be easier to install, you wouldnt need the JDM ECU and the wires. Could you maybe get the 2.8 with the AVCS heads and the JDM ECU? MOre complex, but what a setup!
Old Oct 23, 2004 | 10:49 PM
For max power applications, you want a 2.35 liter stroker EJ22 engine. With forged internals, it's the strongest Subaru block available, with redline capabilites above 10k with the right internals.
Old Oct 26, 2004 | 08:12 AM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
But you'll have to pay serious attention to cooling because a closed deck block isn't exactly efficient in those respects. Stout as hell? Yes. Cooling efficiency? Not as much.
Tim Kelsch
www.stoptech.com
Old Oct 26, 2004 | 10:23 AM
If your coolant system has a nice large capacity, and your radiator is big and efficient, you won't have cooling problems. As for more displacement, when you bore out the motor, it gets inherently weaker. And with turbo OR NA cars, the more revs you can make power at the better. Remember that hp is a function of torque and RPM. The more revs you have, the more air you flow through your motor, whatever size it is.
Old Oct 26, 2004 | 10:24 AM
DAMN i guess everyone is getting the spec C im behind
the JDM 2.0 has a higer red line 8k not 7k
b3atbxr
Jul 9, 2006 05:17 PM
DesolationSuby
Apr 13, 2006 02:59 PM
geoff
Jan 24, 2006 12:34 PM
riceracer
Wanted
Sep 25, 2005 11:55 PM
