intercooler spray
Old Jul 10, 2005 | 10:57 PM
blackwag's Avatar
intercooler spray
is too much spray bad 4 your car? could it flood or somthin? i was thinking about geting a spray kit 4 my o2 wrx and the cusco sray kit can sray quite a bit, i imagine myself goin nuts. thanx
Old Jul 11, 2005 | 01:15 AM
spoolinwrx's Avatar
Car Info: 02 WRB WRX Sedan
Water doesnt go inside the intercooler.
Old Jul 13, 2005 | 04:56 AM
Boost Addict's Avatar
It wont flood as long as you teach your I/C to swim.
Old Jul 16, 2005 | 12:19 PM
TheScoobyMedic's Avatar
Car Info: 05 wrx
Lightbulb
ahahah SIIIIIIIICK
Old Jul 16, 2005 | 08:39 PM
Peaty's Avatar
You only want a very light mist, it's the water evaporating that cools the IC. Too much spray and you soak it preventing it from evaporating and that can be counterproductive keeping the heat in.
Old Jul 16, 2005 | 11:41 PM
jwrx's Avatar
Car Info: 04 WRX Sedan
i dont think water is going to act as an insulator and prevent heat from escaping in case you soak it. the heat from the IC is whats causing the evaporation. if you spray just a fine mist for a second or two, its going to evaporate quickly, and therefor would only exchange a small amount of heat. the more you spray, the more will evaporate, provided there is enough heat to evaporate an amount of water.
my concern wouldnt be 'soaking' the intercooler, but where the water is going to run off when it hasnt all been evaporated. i wouldnt want my spray dripping and causing something under the IC to rust.
Old Jul 17, 2005 | 06:16 AM
Peaty's Avatar
The latent heat of vaporization is larger than the specific heat of water. If you put so much water on the IC that it prevents the ability to evaporate it will be counterproductive.
From the MRT website:
The specific heat of water is 1 calorie or 4.184 joules absorbed to HEAT 1gram of water by 1degC
The latent heat of water is 540 calories or 2260 joules absorbed to EVAPORATE 1gram of water.
In other words the heat absorbed by water is negligible (in massive volume sense NO evaporation) BUT when it is evaporated the benefits are huge.
around 5 to 10 times greater
Old Jul 17, 2005 | 06:38 PM
jwrx's Avatar
interesting... can you post a link to where you found this info? id like to read more into it.
Old Jul 22, 2005 | 01:28 AM
snobrdgy14's Avatar
how much and where can you get a intercooler sprayer kit for a 05' WRX?
Shaggy&Scooby
Jun 17, 2003 04:25 PM
Astacun1
Feb 21, 2003 04:04 AM
Karaya Eins
Feb 13, 2003 06:31 AM
B18c1
Feb 1, 2003 10:22 PM
N/A
Nov 29, 2002 01:06 PM
