Intake Silencer Mod...
Old Nov 6, 2003 | 04:41 PM
RussB's Avatar
Car Info: $200,000 sports car
I currently have an AEM short ram on my Rex, and i'm going to go back to the stock airbox tomorrow (never really gave the stocker a chance), but do the silencer mod in the process. what works best on this mod, leaving the hole open, putting in a velocity stack, cutting open the side of the box with the hole, etc...?
Old Nov 6, 2003 | 05:48 PM
Choku Dori's Avatar
Car Info: Corvette Z51
I can feel it coming.....
ScoobyBoy? mmboost? Peaty?
Old Nov 6, 2003 | 06:07 PM
Salty's Avatar
I put in the velocity stack so you're obiviously familiar with it. If you do a serch with "velocity stack" and my handle "sisqocqk" you should run into some good threads regarding the same topic.
eric
Old Nov 6, 2003 | 06:10 PM
Salty's Avatar
I have $100 on Peaty... he's helped me out a few times. you can count on him.
overall, i did the velocity stack exactly as stated on scoobymods.com. it works very well. BTW i also had a AEM and BLITZ SUS before the velocity stack.
goodluck, eric
Old Nov 7, 2003 | 04:17 PM
RussB's Avatar
ok, i put the stock airbox back in following the process on scoobymods.com. unfortunately, all i could find today was a crappy fram air filter, but oh well. initial impressions... that aem intake was a waste of money. mid range and top end are about the same, and low end is definitely smoother in delivery.
eric, i noticed your car is automatic? so's mine... pm me with what you've done to your car so far please.
Old Nov 8, 2003 | 06:13 AM
Peaty's Avatar
You rang?
Before you put the airbox in remove the ring around the opening tht goes into the fender (where the silencer plugged into) It will give you more of an opening.
This thing:
Put somehting to bridge the gap between the fender and airbox.
Then get a fender plug for the hole that the front part of the intake came out of. THe OEM PN for that is:
46059FA000
Myself I haven't installed a velocity stack myself so I won't comment on it other than to say I'm guessing it won't hurt but don't know how effective it will be. When the air passes through the filter I think will get straitened out and any turbulence that you get coming in the fender hole will be gone.
As for a filter, I've started using Green Filters and prefer it to a K&N.
http://www.scoobymods.com/forums/sho...&threadid=2271
Old Nov 8, 2003 | 09:43 AM
RussB's Avatar
ok, i did remove that thing from the box, and as for the plug, i think i'm going to order those and the brake ducts from subaruparts.com. where's a good place to get a Green Filter?
bsuby36
Dec 11, 2005 09:20 PM
RU-X
24
Jan 5, 2005 01:13 PM
myroncuz
Jan 17, 2004 08:44 PM
skoobieblue
Dec 29, 2003 09:50 AM
Ben
Aug 28, 2003 09:18 PM
