Installing Stromung DP!
Old Mar 31, 2004 | 10:23 AM
wrx10404's Avatar
Car Info: 04' wrx
I am lazy. I went to a local shop and they installed the stromung turbo back for $90. It took a little work and lots of weird extensions. Midpie back came off like a dream but that damn dp was a little stubborn. I think the heatsheild was in the way a little. It went back on pretty easy. Up to you i guess. He had a lift and it took about an hour.
Old Apr 1, 2004 | 10:22 AM
bone324's Avatar
Car Info: '02 WRX WRB
Originally posted by Dallas P&P
Dont waste your money on the local muffler shop. Installing a DP is a very simple process and should only take you about 1.5 hours at most.
Yeah, that's what everyone says. I did mine myself and had a seized downpipe nut. So, after a few hours of stripping the hell out of that I gave up, bolted everything back on (halfway) and drove to the shop. The guy had to use a pipe wrench and all his strength to get the nut off. Anyway, it ended up taking me about 6-7 hours and alot of worrying. So, do whatever makes you happy. $90 isn't alot of money. By the way, since then I've replaced my stromung downpipe with a Vishnu turboback by myself with no problems whatsoever. Good luck.
Old Apr 1, 2004 | 11:32 AM
SlickmisterN's Avatar
Car Info: 2004 Black/Gold STi
Is the Stromung down pipe fully divorced?
Old Apr 1, 2004 | 12:38 PM
DizzyWRX's Avatar
I had a similar problem. I simply couldn't get the bolts off to remove the dp from the turbo. I finally found a pipe to extend the wrench and cheated that way. After about 4 hrs, i finally had my turboback fully swapped out. It's a pain. It might be worth paying $90 to have a shop do it, however i do have more self satisfaction knowing that i did it myself. I hate to see what replacing the uppipe would be like.
atf78
Jul 11, 2009 01:45 AM
Zoeb2s
Feb 10, 2005 01:04 AM
TitanWRX
Nov 23, 2003 12:15 PM
SSFWRX
Dec 20, 2002 05:12 AM
XwrxX
Dec 17, 2002 05:52 PM
