installed exhaust....need help....
Old Apr 17, 2004 | 11:22 AM
wrxless's Avatar
so i bought a blitz nur spec cat back from someone with a bug eye wrx. i have a 2004 wagon. he gave me two exhaust gaskets, one to go inbetween the mid pipe/down pipe and the rear section of the cat back, and the other gasket to go in between the rear section of the cat back and the muffler.
when i took off the oem pipe after the down pipe, i found that there was no gasket, and the one he gave me did not fit onto the oem down pipe. i called him, but he said that it fit his.
am i doing something wrong? or does that my04 not need a gasket there?
i just put it on without the gasket cause i didn't find an oem one when taking off the stock exhaust.
thanks
-tj
p.s. the silencer goes in big side first right? thanks
Old Apr 23, 2004 | 04:19 PM
SlickmisterN's Avatar
Car Info: 2004 Black/Gold STi
Thats weird, on my STi there was a gasket between the midpipe and the downpipe.
Old Apr 26, 2004 | 10:30 PM
escaflowne's Avatar
Car Info: 2004 Black WRX wagon
hmm. when i got my exhaust, it didn't even have gaskets. fits fine. no leaks. muffler shops have a superfluous amount of em.
Old Apr 27, 2004 | 01:33 AM
MonkeyAB's Avatar
Car Info: 2001 Impreza 2.5RS(Ti)
maybe he had a downpipe too. My stock pipes didn't have a gasket there. Don't worry about it.
Old May 4, 2004 | 02:47 PM
Fatal Velocity's Avatar
Its not something to "worry" about but if you have the time to locate and install a gasket I recomend it.
Old May 4, 2004 | 03:15 PM
DizzyWRX's Avatar
That is weird. I have an 04, and when i swapped out my exhaust, there were gaskets between all flanges of the entire turboback. But i guess as long as there isn't an exhaust leak, it should be ok.
Old Jun 9, 2005 | 04:16 PM
Island Style's Avatar
Donut gasket...
I know this thread is older but...I thought I would put this in for future searchers...
On the stock exhaust, there is not a "flat" gasket like most of us are use to seeing...instead there is a "donut", kind of a cork looking gasket that fits in between the stock downpipe and stock catback...
You have to carefully pry it out of the pipe to get it out... a lot of cat-back systems are not made to use this donut gasket and supply their own...
gsxr907
May 3, 2007 11:07 AM
Winding Master
Feb 1, 2006 11:22 PM
voyager2000
May 29, 2005 03:58 AM
timl
May 25, 2003 08:33 PM
drew888
Feb 4, 2003 05:10 AM
