Injector noise? CLICK TAP CLICK?
Old Mar 2, 2004 | 10:45 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
Anybody get an off beat noise from motor when first fired up from cold?
CLICK........CLICKCLICKCLICK....CLICKCLICK..CLICK. ..CLICK
Only for about 45-60 seconds....then it subsides.
Doesn't have the "clack" or "tap" of a mechanical noise.
thanks
Jim
Old Mar 2, 2004 | 11:24 PM
Uncle Scotty's Avatar
A relay maybe...???
Old Mar 3, 2004 | 07:14 AM
ride5000's Avatar
injector noise doesn't stop as the engine changes temperature.
ken
Old Mar 3, 2004 | 07:40 AM
meilers's Avatar
This is the noise from the solid lifters; it comes from the valve train, not the injectors. Totally normal; when they get bathed with enough warm oil (a few minutes after start) they go quiet.
Old Mar 3, 2004 | 12:13 PM
jimr's Avatar
I had a slight suspicion that it may have been valvetrain, but was afraid to consider that. So what happens to these parts (wear-wise) before the oil gets there?
I would imagine that the followers or buckets ride in a pressure-fed, machined relief in the head. It is scary to think that oil pressure isn't reaching these for 45-60-90 seconds!! ????
From looking at diagrams of the valvetrain on this motor, it looks like the cam lobes contact the followers (or adj shims) directly.....without lubrication, what is this doing to cam lobe wear at cold start up?
I will have to look at my oiling flow chart for this motor.
Old Mar 3, 2004 | 01:39 PM
meilers's Avatar
The oil is there, it is just cold, and thus it doesn't flow as well as it does warm. I first noticed this sound on my 02 WRX when I switched to synthetic oil of a slightly lighter viscosity than the dino oil before it; for some reason, the lighter oil made a difference.
BoostedB
Sep 12, 2011 10:25 PM
dippedinsauce
Sep 8, 2010 02:07 AM
stuckinorbit
Oct 30, 2005 01:07 PM
WRX151
Mar 20, 2003 04:37 AM
Steppin Razor
Jan 29, 2003 03:56 AM
