Impreza project
Old Mar 24, 2004 | 03:48 PM
go buy an old blazer
Old Mar 24, 2004 | 06:24 PM
Choku Dori's Avatar
Car Info: Corvette Z51
Just so you know, the WRX IS an Impreza. I assume you're in the market for an Impreza 2.5RS right? It's a very solid car and a joy to drive, and the AWD makes life much easier in snowy and hilly places like Pittsburgh.
You don't want an air suspension in your Impreza. Air suspensions are for behemoths that don't need to worry about tight handling and cornering. I suggest you go with adjustable dampers instead - they offer flexibility in your ride height and stiffness, and when properly set can offer you anything from a ride similar to the stock suspension to a lower race-oriented setting.
The 2.5RS is already quite well-powered, and its low rev torque line is superior to the WRX's. You should take this into consideration if you need to navigate snow and hills at low revs. An alternative to engine swapping with a WRX would be to turbocharge the stock 2.5 liter for more power up top.
Hope you enjoy your Impreza
uselesstool
Dec 3, 2009 10:01 AM
jimtweet
Jun 29, 2006 05:59 PM
Weak Sauce
Feb 15, 2006 05:05 PM
British Banger
May 5, 2003 11:06 PM
