I'm SKEEEERED!!!! (Will my mods blow up my engine?)
Old Jan 28, 2004 | 10:34 PM
DLUX WRX's Avatar
i dont think you have anything to worry about unless your ECU is not set up correctly and your runing a map that will blow your engine.
Old Jan 29, 2004 | 08:16 AM
wrx10404's Avatar
Car Info: 04' wrx
Re: I'm SKEEEERED!!!!
Originally posted by jkwon
I am hearing a lot of horror stories out there about people blowing their engines with similar mods to mine. And my question is...how realistic are my fears. I currently have catless down and midpipes, accessECU, sti perf. exhaust, for engine mods. and other handling mods which i'm not too worried about.
so...what do YOU all think?
--joe
Did you buy the accessecu from cobb. Ask them. I think you'll be ok. I hope, I am going to run basically the same set up. TBE, stage 2.
Old Jan 29, 2004 | 11:35 AM
sKOOTeR WRX's Avatar
Car Info: WR Blue WRX
I am running the same setup and I have read that this is fairly reliable. I wouldn't be to worried unless you are running an additional boost controller and are pushing it above what is reccommended from cobb.
Sounds safe as long as you are running the right octane.
Old Jan 29, 2004 | 11:57 AM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
And an STi shortblock + install and supporting parts is probably only $4,000. So what's to worry!
Old Jan 29, 2004 | 02:47 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
oOoOoOo....STI short block good call...I doubt your engine will blow up....very rare with the set up you got, it gets more intense when you get a bigger turbo and injectors but your running stock so your fine..
Old Jan 30, 2004 | 09:53 AM
AWD 20T's Avatar
Car Info: 2009 G Ride
Just to reinforce all the previous opinions, I too do not see any problem with your setup... Enjoy!
Old Jan 30, 2004 | 12:39 PM
iLoqin's Avatar
Car Info: Nadda
Boost sub 16 please.....
Old Jan 30, 2004 | 03:59 PM
my2003wrx's Avatar
Just don't redline your car for 7 minutes and you'll be fine
:banana:
