I was reading about boost control and found this idea
Old Mar 24, 2004 | 12:34 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
I don't think I'd try this, but I thought I'd share what I read
This book I have on forced-induction motors......the chapter on boost control, there is a short write-up on a cheap (!) boost control.
In the hose that runs from compressor housing to stock solenoid (where some guys install the 3/16), using a hot pin-vise or needle, bore a .020-.040" hole thru the plastic coupler so it will vent a small amount of signal to stock solenoid to the atmosphere, thereby "delaying" signal to solenoid and delaying wastegate.
Sounds like holed-pistons to me, but has anybody else heard of this??
Or relocating the source for boost signal from compressor to intake manifold??
Like I said, I'm not advocating this......just wondering. I'm not trying it.
Old Mar 24, 2004 | 12:59 PM
Ditty77's Avatar
Car Info: 2002 WRX
run a search on "3/16 mod" it's been discussed alot.
I did it before i got an ebc.
Old Mar 24, 2004 | 02:49 PM
theworx's Avatar
Car Info: 04 Java Black Sedan
Most MBC's will come with a hole like what you describe.
Old Mar 26, 2004 | 09:08 AM
ride5000's Avatar
you're essentiallly adding a bleed hole.
it will work. downside? non adjustable!
needle valves work just as well and can be tweaked.
jm2c
ken
wrXtian
Sep 1, 2008 04:53 AM
K I T T
Apr 8, 2005 12:59 AM
WRC_Scooby
Jul 31, 2004 04:01 PM
Astacun1
Jun 28, 2003 03:12 PM
rlarose
Jun 11, 2003 03:06 AM
