I need help, oil in intercooler.
Old Nov 16, 2005 | 08:06 PM
REXX13's Avatar
Car Info: 03 SILVER REXX, 2.5ltr, vf34, sti cooler
Angry I need help, oil in intercooler.
Sorry to keep posting on this but I can't figure this out. I have oil in my intercooler and compressor outlet and throttle body and I mean alot of oil when I tip the intercooler over it will drip out alot. I have an oil catch can that is connected to the two valve cover lines and the one on the crank case and it does not have any thing in it after 6 days. I've already replaced my turbo so thats not it. The screwy thing is thats the only place it can be coming from. I also get alot of blue smoke but it's only under boost when it dose it. Has anyone ever seen this or heard of this. Please help I've already talked to the shop and they don't no. The only suggestion they had was that I have a restriction in the return oil tube on the engine underneith the turbo and I have to pull the turbo to check that to make sure I have good flow.
Thanks, Troy
Old Nov 17, 2005 | 11:12 PM
DEMENTEDWRX's Avatar
Car Info: '06 Lexus IS
either your turbo seal is blown or your return line is leaking...
my guess is you have a blown seal.
Old Nov 17, 2005 | 11:42 PM
mbquarts's Avatar
Car Info: 03 MBP WRX
check/replace your pcv valve.
Old Nov 18, 2005 | 08:35 AM
REXX13's Avatar
yeah I checked the pcv it's good. I have alot of oil coming out of the crank case too. But how is it getting into the turbo all of my pcv lines are going into the catch can? What causes the crank case to let out all that oil is there something wrong in my engine?
Old Nov 20, 2005 | 08:27 PM
REXX13's Avatar
my engine is bad. low compression in both driver side cylinders.
Thanks for the help, Troy
Old Nov 20, 2005 | 09:09 PM
My_Red_Suby's Avatar
Car Info: 2005 Metallic Gray STI
change back to stock..... re-install
Old Nov 20, 2005 | 11:18 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
sounds like blown piston rings....that sux....I'm sorry to hear. So how'd that happen? You havent been bouncing off the rev limiter recently have you?
huck
Aug 23, 2017 02:18 PM
Snoshado
Forester General
Sep 9, 2012 09:51 AM
Slack
Aug 25, 2003 09:45 PM
Zoeb2s
Dec 30, 2002 10:43 AM
