How much HP for Stock motor?
Old Aug 31, 2004 | 07:17 PM
dorifto88's Avatar
stock motor, yah sure.
stock tranny... meh
Old Aug 31, 2004 | 07:22 PM
AzN121184's Avatar
Car Info: civic
a lot of people run that setup on stock transmissions fine.
and we also have a handful of those who break their transmission on a all stock car.
the motor will be able to take it.
Old Sep 1, 2004 | 02:15 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Originally Posted by crxsirvtec
hey..
i was wondering how much a 2002 WRX USDM will take??
There is a company local here that can give me 280 WHP for 1600$ USD
New VF34 Turbo
600 cc injectors
255 lph fuel pump
ECUTEK RE-flash
not sure what they run the boost at..
but 280 WHP is like 370 to 390 Crank HP..
how will the stock motor take this??
Does your car already have a TBE?
Old Sep 1, 2004 | 05:48 PM
JAYSPEED's Avatar
Car Info: 02 Wagon
if you ar not drag racing then you will be fine. Try your setup on a nice open field or parking lot......Rally that thing....
Old Sep 1, 2004 | 06:12 PM
MO REX's Avatar
TBE???
what tranny would bolt up and be stronger then the USDM 2002 WRX 5 spd??
TBE=Turbo Back Exhaust. You will need an aftermarket TBE to run that setup and I was wondering if you already had one.
Here is the answer to your tranny question (very expensive) https://www.i-club.com/forums/showth...?threadid=3540.
Old Sep 1, 2004 | 06:27 PM
SooKy's Avatar
500hp max for stock motor?
Old Sep 2, 2004 | 07:00 AM
ride5000's Avatar
there is no set max. reliability takes a sharp turn for the worse at around 300whp, from what i've seen, but you can certainly run a lot more than that. your margin of error simply becomes razor thin.
jm2c
ken
Old Sep 2, 2004 | 12:03 PM
Choku Dori's Avatar
Car Info: Corvette Z51
TBE???
STi six speeds are a helluva lot stronger. Or just get an auto
Old Sep 2, 2004 | 03:03 PM
Got Groceries?'s Avatar
Car Info: 2003 WRX wagon
Or an RA 5-speed gearset...stronger, and better gear ratios.
Old Sep 2, 2004 | 03:22 PM
MO REX's Avatar
You are correct, but gearsets are also prone to failure due to how the stock WRX tranny case flexes. I dont know this from personal experience but there is some info about it in the link I posted above.
Got Groceries? I just sent you a PM.
greenpoop
Jul 9, 2009 08:31 PM
gruppe-s
Apr 11, 2006 07:12 PM
gruppe-s
Engine and Drivetrain
Apr 11, 2006 07:10 PM
Fulloutpwr
Mar 6, 2004 01:21 AM
PimpWagon
Jan 4, 2003 08:03 PM
