How much boost can stock motor handle?
Old Jan 4, 2003 | 04:26 AM
18hrwrx's Avatar
Car Info: White on Gold STi
Is that in the efficiency range of that turbo... It doesn't make any sence to run boost that is out of the efficiency range, but to kind of anwser your question people are running bigger turbos with that boost.
Mike
Old Jan 4, 2003 | 05:29 AM
IS2Scooby's Avatar
Pr0n King
Car Info: Turncoat Turbo
Seems like VF30's pump their best at 18psi:
IHI VF-30 460 CFM at 18.0 PSI
From hotrod's flow FAQ.
I think there's a definite law of diminishing returns after that.
Guys are running 12.70-80's with Stage 4's + TMIC at this boost level...
__________________
Old Jan 4, 2003 | 10:10 AM
Sloppy Joe's Avatar
Re: How much boost can stock motor handle?
Old Jan 4, 2003 | 12:31 PM
nqwan's Avatar
Car Info: o2 duburu arr exu
Originally posted by PimpWagon
If I were to boost 1.35BAR (with enough fuel) would I damage the turbo or bottom end?
i'd say yes, the stock block can handle it but its the octane and detonation that i'd be worried about.
Old Jan 4, 2003 | 07:23 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
at 1.35bar or 19.2psi, your wasting your time. Stick to roughly (no more then) 18psi or 1.25bar that way your not just blowing hot air.
Old Jan 4, 2003 | 08:03 PM
Rexstang's Avatar
First 12sec WRX in HI
Car Info: 12.93@106.71
Yes your engine can handle it but why stress the engine when 1.25 - 1.3 bars is the max efficiency. Sounds like someone is addicted to boost. God knows I am. Good luck at the track.
VRT Gump
Jan 28, 2008 09:33 PM
lburrrna
May 3, 2007 07:17 PM
michaelstang
Aug 16, 2006 11:15 PM
GrandpreRS
Jul 15, 2005 04:41 PM
gogoman
Dec 29, 2003 05:50 PM
