How much does (Vishnu) up-pipe weigh?
Old Jan 16, 2003 | 04:42 AM
Wingless Wonder's Avatar
Question How much does (Vishnu) up-pipe weigh?
Hello, people. Did you happen to weigh your 321 up-pipe and underdrive pulley from Vishnu? I forgot to do this before they were installed. I noticed that the stock stuff that came off the car weighs a *lot* more. I'm trying to keep a log of weight addition/removal.
__________________
ww
Old Jan 16, 2003 | 02:14 PM
hman's Avatar
Car Info: WRX Platinum Silver Metallic
Great info. Thanks.
Old Jan 17, 2003 | 12:44 AM
Originally posted by Geekqualizer
The Vishnu up pipe weighs 4.5 lbs. The factory pipe with heat shields weighs 7.5 lbs.
The Vishnu underdrive pulley weighs 1.5 lbs. The factory pulley weighs 5.0 lbs.
Geekqualizer, thanks a bunch for the information - much appreciated.
If you only fill your windshield washer reservoir to about an inch above the supply pipe you will have a half dozen or so windshield squirts and you will save an additional 7 pounds!
Nice tip. I've noticed that the reservoir has a pretty large capacity. Maybe it's a WRC design.
__________________
ww
Old Jan 17, 2003 | 05:18 AM
The windshield washer tip is only good if you don't live in the winter snows of New England!
I learned this the hard way one stormy night on a salted highway. What was I thinking?
Here's a simple answer to our wintertime woes:
1) Fill washer reservoir to minimal level for weight savings.
2) Stash washer solution jug in trunk for quick refills when reservoir runs dry.
__________________
ww
Fatal Velocity
Jun 29, 2004 01:42 PM
escaflowne
Dec 30, 2003 05:50 PM
nick van exel
13
Sep 20, 2003 01:33 PM
rudedogsurfrat
Feb 27, 2003 11:12 PM
joe mama
Jan 6, 2003 10:52 PM
