HKS downpipe
Old Oct 12, 2003 | 07:10 AM
ride5000's Avatar
Originally posted by BAN SUVS
The wastegate remains closed until after the turbo has fully spooled and boost is reached.
not necessarily.
ever hear wastegate flutter?
that's the WG opening way before it's "supposed" to.
jm2c
ken
Old Oct 12, 2003 | 03:32 PM
That's a broken or failing part.
Old Oct 13, 2003 | 05:51 AM
ride5000's Avatar
wow. i'm surprised you think so.
the wastegate is held closed by a spring, not a solenoid that switches on and off in a binary state.
the spring's tension must be overcome by the gas pressure differential across the wastegate actuator before the wastegate starts to crack open.
the thing is, this does not occur suddenly and completely.. it is a gradual process.
as the pressure starts to rise across the actuator, the spring will start to have less and less effective pressure. at wastegate spring pressure, the two forces have cancelled each other out and the wastegate is free to flap open completely.
as the effective spring tension is reduced, the increased momentary pressure at the turbine inlet caused by exhaust gas pulses tends to blow open the wastegate (it does open "downstream" as you will remember) for short durations. this tends to happen at part throttle, mid rpm range conditions.
this is wastegate flutter. some have reported success at reducing (but not eliminating) the flutter by adjusting the acutuator arm length, essentially increasing spring preload. nevertheless, it is quite normal, and quite ubiquitous on our cars, and does NOT represent something "broken or failing."
unless you have a VERY effective ball/spring type MBC which COMPLETELY prevents pressure from reaching the wastegate actuator until the setpoint is exceeded (and i haven't seen one yet) then it is impossible to prevent this from occuring to some extent.
if you've got another explanation for wastegate flutter, i'd love to hear it.
hth
ken
Old Oct 13, 2003 | 05:54 AM
krillz's Avatar
Car Info: black o2 sedan
the wastegate on our cars starts to opem at like 7 psi and continues to open as boost rises
Ban Suivs: I have a flat flange, and i like to defend it
Old Oct 13, 2003 | 02:35 PM
ride5000's Avatar
that is true, it would just start to open at 7psi--IF there was no pressure on the pre-turbine side from the exhaust gasses. it does not take into account the pressure of those gasses which may cause the WG to open prematurely.
the only thing which can prevent that (premature WG opening, wastegate flutter) is a higher rate spring or additional spring preload.
hth
ken
domchao
Oct 24, 2014 08:11 AM
flatline
Apr 18, 2008 09:36 AM
ASpec818
Apr 7, 2004 02:04 PM
BennieSubWrx
Jul 18, 2003 02:59 PM
(==ImPrEzAWR==)
May 17, 2003 11:22 PM
