00 rs cel fix
Old Oct 13, 2003 | 05:30 PM
mrtrex's Avatar
Car Info: 02 WRB WRX
check out www.evailmotorsports.com We have cheap cel fixes. You have to wire it into the rear o2 sensor. They will work on your for the p0420 cat code.
Old Oct 13, 2003 | 11:52 PM
It is almost certainly the Borlas. They lose a lot of heat due to the lack of heat shields, insulation, and being single wall tubing instead of the stock double wall. This makes it impossible or at best difficult for the catalytic converter to reach operating temp. Put your stockers back on, reset the ECU, and get smogged. The Borlas won't pass the visual anyway. In fact, nothing will pass the visual except for a catback system.
Old Oct 14, 2003 | 10:48 AM
Wrapping and painting the Borlas might do the trick. I plan to coat mine and then wrap them once I get my turbo kit put together. I will probably do it before then to verify that it gets rid of the CEL. I have heard though that Borla voids their warranty if you wrap them, but I don't think it's a big deal. The worst that can hapen to them is they need a bit of welding on a crack.
esracer
Mar 16, 2004 11:56 AM
fungracing
Jan 9, 2003 02:04 PM
mrtrex
Vendor Group Buys/Specials
Dec 23, 2002 05:50 PM
gruppe-s
17
Dec 21, 2002 04:08 PM
jjunior887
Dec 15, 2002 02:20 PM
