HKS downpipe
HKS downpipe
I just purchases a HKS Downpipe, and now I've read some old posts that say to avoid them? I've also read just as many that say its fine?
So what's the scoop....are people just saying there's better downpipes? It can't hurt the car right?
Ryan
Ryan
Car Info: dream car Subaru STi
itll hurt the car if u have a check engine light, so make sure wen u get ur hks downpipe installed, u also get a reflashed ecu thats is programed to handle ur new mod.
yea
i bought it, and read about how it can be a problem i cancelled my order and got a helix down pipe to go with my helix up pipe
its worht the more $
i absolutely love the difference
there's no need to get a very expensive reflash to solve that problem when 2 bucks worth of parts from radio shack will do the trick. if you're not electronically inclined, a pony express MIL eliminator will do as well.
jm2c
ken
You could just pick up the CEL fix from www.gruppe-s.com No worries.
Originally posted by TurboWrx
I found out, that the HKS downpipe doesn't let the wastegate gas flow.
Nothing wrong with the HKS or any other OEM style dp. The Bellmouth design isnt exactly ideal, though... you still get some turbulence. A divorced wastegate is probably the only logical upgrade from stock design. However, I have heard of cars "having trouble with boost" on a divorced wastegate cuz "it flows too well".
Originally posted by DarriiffftaaHuy
So what?! How many stock WRX's or STi's have problems related to the downpipe design? With this "bad design" and a cat, these are capable of about 400hp before its a restriction, and that is the cat, not the design.
You're at a movie theater, and there are 4 exit doors. Your movie ends, and all the people in the theater leave, but there are only enough people to need 2 doors. Now, 2 other movies end as you are exiting, and those other 2 doors are needed. Only, 3 feet past those 2 doors is a wall. How fast do you think the disgruntled moviegoers are now exiting the building? I don't know, but it's not as fast as it would be if that wall weren't there.
The flange design for the hks and the oem is identical. While it may not be ideal, it definatly will not harm your wrx. The price is right, about 150 depending on where you buy it, so grab one and pass it down to another wrx owner when it's time to upgrade again. Or, if you have the cash, buy a godspeed pipe. I've heard nothing but good things about em.
I found out, that the HKS downpipe doesn't let the wastegate gas flow. So, I also cancelled my order and bought a helix. I love it.
if you keep the wastgate closed longer, where is the air going? into your turbo, spooling it.
flat flange = more torque and/or quicker spool
divorced wastgates arent ideal, the wastegate opens on an angle anyway, so if its not fully open, the air is towards the larger pipe creating alot of turbulence anyway
Divorced downpipes usually come with a divider plate to keep wastegate gasses from going to the main exhaust flow. However, that is my theory with bellmouth downpipes, that the wastegate opens towards the exhaust stream and creates turbulence anyways.
Originally posted by krillz
THEORY:
THEORY:
