hesitation (was: Skipping)
Old Nov 30, 2004 | 12:00 PM
mmboost's Avatar
Misfires? Bad spark gap? Which plugs did you use? What modifications do you have?
jason
Old Dec 1, 2004 | 09:18 AM
mmboost's Avatar
How do you know its not misfiring? "Stock replacement plugs", what are those? Did you get pre-gapped plugs from a Subaru dealership or something? Perhaps you should find out what modification are on. What sort of blow off valve and what sort of filter? This straightpipe was catless? 17.5lbs is way too much boost for an "otherwise looked stock" car. Its colder now, I bet you're knocking too.
the better you fully and directly answer my questions the easier it is to answer you questions
jason
Old Dec 2, 2004 | 08:53 AM
mmboost's Avatar
Oooh K&N. Check your MAF sensor to see if its got drips of K&N oil on it. This is what probabaly causes cruising or accelleration stumbling. The poor gas milage is probably do to your BOV, which blows off to the atmoshphere, yes? If that's the case what's happening is the ECU reads air as it flows by the MAF, but the BOV releases a good amount of this air. So the ECU ends up sending more fuel through the injectors than you really need. Bad mixture, bad milage. It also makes for boggy shifts. If I were you I'd just remove the shorty and the BOV and reset your ECU for fun,... sell them to someone who now knows less than you
jason
Old Dec 3, 2004 | 02:02 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
If you noticed the problems only after the spark plug swap, I'd make sure all the plugs are the correct heat range, gapped propperly, torqued propperly, and finally that all the coilpacks are on tight.
Also, as Jason pointed out, 17.5psi is way too much boost for your stock wrx to be running. Did you buy the car with an MBC or EBC? Or maybe you have a reflash? My advice is to figure out your boost control, then dump the intake and BOV.
-- Ed
Old Dec 3, 2004 | 08:48 AM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
I'd bet they cracked the insulator on one of the plugs, causing occasional misfire. Let us know what you find.
platypus
May 11, 2004 01:57 PM
dashiet
Oct 25, 2003 03:17 PM
christoph1371
May 7, 2003 12:01 AM
Zoeb2s
Mar 7, 2003 01:02 PM
Top
