HELP!! Tuning questions for replacing turbo
Old May 13, 2013 | 01:53 PM
  #31
Heedz's Avatar
Nobody likes the tuna here
So does the car feel slow? If anything your gauge MAY be off. Or you have a leak somewhere.
I know someone who threw a 02-03 TD04 into a 04-05 and it didn't boost properly due to the settings of the wastegate.
What other mods are you running?
Old May 13, 2013 | 01:54 PM
  #32
supersubi81's Avatar
Car Info: bugeye
Oh ok! Nope no CEL at all. She runs fine and the torque seems normal but it just feels like she can boost more ..
Old May 13, 2013 | 01:55 PM
  #33
Car Info: bugeye
@ Heeds, im all stock.. Do you know how i can reset my sportcomp gauge?
Old May 13, 2013 | 08:53 PM
  #34
Heedz's Avatar
You should be hitting more than that though. I don't use sport comp. So I'm no help there.
Old May 13, 2013 | 09:26 PM
  #35
Car Info: bugeye
Thanks Anyways Heedz.. Yah i know i was hittn 12psi before i replaced the turbo. I was thinking this new and low mileage turbo was gonna hit harder and better than my last one. Guess i got some more investigation to doo.
Old May 17, 2013 | 10:48 AM
  #36
Car Info: bugeye
Hey Guys so just an update to my issue here.. I finally found out what i needed to do to regain my stock psi back to 12. I needed to replace the actuator from the 2.5L to my original 2.0L and that fixed my boost issue! Thanks again for the help and suggestions guys!
Old May 18, 2013 | 03:09 PM
  #37
Heedz's Avatar
So basically it was opening up way too early.
Old May 18, 2013 | 04:03 PM
  #38
Car Info: bugeye
Im not sure but at least changing the actuator did help and make a bigger difference
Old May 18, 2013 | 04:33 PM
  #39
Concillian's Avatar
Car Info: 02 WRX sedan
I'm curious why you didn't do this when I told you to earlier?
Move your wastegate actuator from your original turbo, unless there's something wrong with it.
Also "setting" the actuator was not to do exactly 6 half turns. That video was for a different turbo. You needed to continue to go tighter until you reached proper boost. Start at 6 half turns, and then go 7, 8, 9, etc... until boost is correct. This would have had the same effect as swapping the actuator.
Old May 19, 2013 | 10:12 AM
  #40
Car Info: bugeye
Concillian, Yeah man i must have missed your part of that response, But yea i figured that much when i was adjusting the actuator.. gotta do more and more if need to which i did. Thanks for checkn back though i appreciate that. Im glad to know there are still people out there who care and help!
Old Jun 17, 2013 | 04:30 PM
  #41
Car Info: bugeye
Whats up yall! So im back unfortunately.. So to catch up on things with this thread i have adjusted my wastegate arm to go the shortest as possible and im still not getting the stock boost. im at 9 now from like 5psi. Bigger difference but of course it could be better. Anyone know any suggestions i can try to fix that? Thank guys in advance!
EQ Tuning
Nov 2, 2017 05:05 PM
O 16581 72452 5
Sep 18, 2003 09:37 PM
