help with stage 4 install
Old Jul 10, 2005 | 10:45 PM
a1cwrx's Avatar
i installed my stage 4 this weekend, then loaded the mep from turbo xs when i started the car it was runnin like crap spitten out all colars of smoke, the logger was saying lean as a *****, turbo xs said it might be my sard intake. im hopein i didnt fry anything, im thinkin about takin to get tuned but id rather not till i finish modin it. any advice?
Old Jul 11, 2005 | 03:34 AM
Wingless Wonder's Avatar
Origami posted by a1cwrx
WRX? STi? You didn't fill out the Car field in your member Profile.
Follow TurboXS' advice and remove the intake. I don't know if that intake causes MAF problems but always follow the advice of the folks who designed your upgrades.
Tuning is always a good idea for full turbo back upgrades. Are you using a UTEC?
Old Jul 11, 2005 | 04:15 AM
a1cwrx's Avatar
its a wrx and a i have a Utec, you think a intake can lean it out that much? thanks for the reply
Old Jul 11, 2005 | 04:34 AM
If that is what you've logged, and if TXS has made the suggestion to swap back the stock intake, then that's what I would try first. Examine your logs again after the swap and see if there was improvement. Are you running the correct map for your other mods?
TXS claims their own 'shorty' intake does not disturb factory MAF calibration although I have no experience with aftermarket intakes.
Old Jul 13, 2005 | 11:27 PM
Those Kids Suck's Avatar
It's doesn't sound like the intake would be the reason, but it couldn't hurt to go back to the stock intake. Are you sure that all of your injectors are seated on the fuel rail properly. Also if you changed your plugs make sure that the coil packs are in all the way seated on the plug tight enough. Also if you took off your TGV sensor during the install that can cause a rough idle too.
unstble
Mar 21, 2008 09:09 AM
Cashis
Mar 17, 2006 03:35 PM
Cashis
Mar 17, 2006 02:12 AM
Cend_wrx
Apr 5, 2003 12:03 AM
pillaka
29
Dec 1, 2002 01:14 PM
