help with stage 4 install
i installed my stage 4 this weekend, then loaded the mep from turbo xs when i started the car it was runnin like crap spitten out all colars of smoke, the logger was saying lean as a *****, turbo xs said it might be my sard intake. im hopein i didnt fry anything, im thinkin about takin to get tuned but id rather not till i finish modin it. any advice?
Origami posted by a1cwrx
Follow TurboXS' advice and remove the intake. I don't know if that intake causes MAF problems but always follow the advice of the folks who designed your upgrades.
Tuning is always a good idea for full turbo back upgrades. Are you using a UTEC?
If that is what you've logged, and if TXS has made the suggestion to swap back the stock intake, then that's what I would try first. Examine your logs again after the swap and see if there was improvement. Are you running the correct map for your other mods?
TXS claims their own 'shorty' intake does not disturb factory MAF calibration although I have no experience with aftermarket intakes.
It's doesn't sound like the intake would be the reason, but it couldn't hurt to go back to the stock intake. Are you sure that all of your injectors are seated on the fuel rail properly. Also if you changed your plugs make sure that the coil packs are in all the way seated on the plug tight enough. Also if you took off your TGV sensor during the install that can cause a rough idle too.
unstble
Mar 21, 2008 09:09 AM
pillaka
29
Dec 1, 2002 01:14 PM
