Help needed ASAP! CEL flashing/no clue why
Old Feb 9, 2004 | 08:55 AM
Rizzo's Avatar
Car Info: Visit my homepage to see everything I have done.
Wow, people here are really helpful.
Old Feb 17, 2004 | 09:15 PM
Rizzo's Avatar
All of the wastegate hoses are fine. I bought an OBD-II scanner and put it on and it says that there is a misfire.
Old Feb 17, 2004 | 09:20 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Keep the greens DISconnected. They are a diagnostic plug that should be disconnected when the dealer gives you the car.
I would bet it's a misfire in one or more cylinders.
edit: I was right! I would guess that the combination of the intake and big turbo is not sitting well with your ECU. What other mods do you have supporting that turbo?
Old Feb 18, 2004 | 04:54 AM
Rizzo's Avatar
The greens are disconnected. They have been disconnected.
Yes, you are correct, it is a misfire in one or more cylinders.
After the problem occurred I took the turbo and intake off. So the car is back to stock in those areas. I did not put anything in with the turbo (injectors, fuel pump, etc) because I thought that the VF39 was only slightly larger and did not require them.
Old Feb 18, 2004 | 09:04 PM
EvoEater's Avatar
Car Info: 03 WRX silver
I have the same problem right now
nic3krnnamja83
Jun 23, 2014 08:13 PM
kyle_RS
Jan 7, 2007 04:20 PM
Flauntinghippo
Aug 26, 2005 07:49 PM
808imprezaRS
Feb 19, 2005 07:36 PM
mrmodex
Jun 18, 2004 08:53 AM
