help.. changed exhaust and im having vibrations
Old Jul 25, 2011 | 10:36 PM
doubleU_AREx's Avatar
Car Info: 2002 WRB WRX
hey.. i swapped catbacks with one of the iclubbers and now i have this vibration at only certain speeds.. noticed it on the freeway.. what could it be? exhaust leak? loose bolts? or hitting something?.... help would be appreciated.. btw i have a 02 wrx with turboback.. thanks.
Old Jul 28, 2011 | 03:15 PM
1SIKBRU's Avatar
Car Info: Audi Q5 aka "the old man wagon"
If you haven't already found the problem, take a look at ur rear diff and ur rear sway bar, if the pipe is really close to either of those it could be hitting them. Other than that, leaks shouldn't cause vibrations, and loose bolts would be rattling so you should be able to hear them from outside the car with it idling. Good luck.
Old Jul 30, 2011 | 05:37 PM
Imported209's Avatar
Car Info: 05 asp white wrx
i have the same problem, but mine was hitting on my car. if you can jack the car up and jiggle the exhaust around you can see where your hitting IF you are. then from there use a cushion of some sort. I used a glob of double sided tape at both my locations. not the best fix but it deff helped out.
Old Jul 30, 2011 | 06:16 PM
Javirex23's Avatar
Car Info: 07lmtd 6spd wrx eq tuned
I'm sure longer exhaust hanger will fix that issue, I'm on the same boat as you, lol
Old Jul 31, 2011 | 11:01 PM
meilers's Avatar
That pipe gets to be about 600 degrees, that tape won't last...
Old Aug 5, 2011 | 01:56 PM
Really? Mines been on for 6 months through track days and summer. Seems good to me lol. Want pics?
Gancherov
Jan 23, 2010 01:52 PM
imprezzedEJ25
Jan 8, 2006 02:26 PM
kramer
Mar 11, 2005 09:44 AM
imprezzedEJ25
Dec 17, 2003 01:53 PM
scaryfast
Feb 4, 2003 11:00 AM
