Helix DP /w Stock Catback Leak
Old Apr 27, 2004 | 08:22 AM
battousai's Avatar
I just bolted up the Helix Downpipe to my stock catback. It leaks at the very top of that 2 bolt flange. Does anybody know how to solve that problem? I've tried tightening it as much as I could, but it still leaks at the very top.
Old Apr 27, 2004 | 08:32 AM
my2003wrx's Avatar
Did you put in new gaskets?
:banana:
Old Apr 27, 2004 | 08:37 AM
battousai's Avatar
Yeah, I used the new gasket that came with the downpipe.
Old Apr 27, 2004 | 01:52 PM
killaho's Avatar
UTR Member
Car Info: 93 Impreza L
the 2 flange between the dp and the exhaust?? did you put that donut gasket on there??
Old Apr 27, 2004 | 05:56 PM
battousai's Avatar
Yeah, I tried to adjust it at work today.. but it didn't work. It was a donut gasket and it looked like a perfect fit, but it still leaks at the very top. I guess it is because the DP is 3" and it is mating to a 2.5"(?) catback. Any solution to it?
Old Apr 27, 2004 | 07:05 PM
my2003wrx's Avatar
You could get a catback? Or find a 3'' to 2.5'' pipe that goes from the downpipe to the axleback.
:banana:
Old Apr 28, 2004 | 03:47 PM
psychobooe's Avatar
Take your car to a muffler shope and have them weld a flange onto the cat-back. That's what I had to do. They just welded a 3" flat flange that necked down to 2.5" onto the cat-back and everything fit perfect.
Old Apr 29, 2004 | 11:04 AM
killaho's Avatar
UTR Member
get a new cat back that or get a new mid pipe. i have the oposite set up as you ( stock dp to 3"+ catback) and theres no leak issue. maybe check your hangers too the stock ones are way soft and your catback might be hanging down causing the top to leak... some upgraded ones will solve this too.
Old Jul 15, 2004 | 11:40 PM
Zoeb2s's Avatar
I <3 White Girls
I have heard the helix downpipe doesn't mate up to the stock exhaust as well, something about the design, especially b/c its so much bigger then the pipping on the stock exhaust.
Best bet would be to mate it up to an aftermarket catback or get a custom flange for your stock catback.
Old Jul 16, 2004 | 12:10 AM
FiDRcr's Avatar
Helix DP does match up with stock cat-back. You can either purchase a 2.5 inch gasket or use different nuts and bolts instead of the spring ones.
brucelee
Aug 2, 2010 09:39 PM
gruppe-s
Engine and Drivetrain
Aug 11, 2006 05:34 PM
ScoobyRoo20
Sep 9, 2003 04:43 PM
bigdaddy
Jul 10, 2003 12:09 PM
