Guide me to 320 hp
Old Dec 17, 2002 | 12:06 AM
  #32
STi Ver 1's Avatar
Car Info: JDM Ver 7
Originally posted by stilesg57
Acually, the number on the IHI turbos has to due with the order in which they were designed, nothing more. Case in point: A VF22 puts out less than a VF24, which puts out the same as a VF29, both of which put out less than a VF30, which puts out the same as a VF34 although the 34 spools faster, both of which put out more top end than a VF35 which spools faster than either the 30 or 34.
IOW, the number only designates the order in which they came out, nothing else about the turbo or its power/spool abilities. Therefore the only thing that can be said about the IHI's judging from the number alone is that the VF22 is an older (though not neccessarily less powerful) turbo than say the VF30, which is older than the current newbie the VF35. Hope that helps a little.
The VF-22 is the bigest of the VF's, and bigger than a VF-24. VF-24 was stock on some of the Limited STi's.
Old May 21, 2003 | 01:17 AM
  #33
240sxer's Avatar
what about 300 awhp, would you need for that?
which turbo would get you aroun that power level with the lease lag? and would a STi TMIC be enough to hold up to that power?
Old May 21, 2003 | 04:17 AM
  #34
davenow's Avatar
Stiles check your facts man
The vf 22 is HUGE compared to the 24 and 29. I know what a 24 is. I have one on my car.
The VF 22 puts out more than a VF30!The 24 and 29 spool VERY quickly, the 22 spools in the mid 4000's but MAN O MAN when it spool you know it
300WHP?
here is how
Good engine management
vf30-or better yet vf22
FUll catless exh and up pipe
sti or larger injectors
Fuel pump
Bigger intercooler (sti isnt going to cut it here)
GOOD dyno tune
You are also going to need
Better clutch
Good driving skills to not waste your tranny.
Old May 21, 2003 | 12:04 PM
  #35
240sxer's Avatar
i will mostly be autoXing. so i dont want a turbo to spool @mid 4000 when does the vf30 spool? or the 29? you say it spools quick? how quick.
Old May 21, 2003 | 02:51 PM
  #36
davenow's Avatar
Well, I have a 24, which is basically identical to the 29, and I barely notice a difference. It spools PLENTY fast for autocross.(which I do)
Old May 21, 2003 | 07:24 PM
  #37
240sxer's Avatar
how much power you putting out? whats your set up??
Old May 22, 2003 | 04:30 AM
  #38
davenow's Avatar
Well,not as much as I could be, I dont have the fuel upgrades in yet. But its over 300 at the crank thats for sure.
Christian.
Apr 17, 2007 02:34 PM
SSFWRX
Nov 3, 2003 05:31 PM
WRXfreak
Cars For Sale
Oct 11, 2003 11:18 AM
yamaha1995
Jul 3, 2003 03:16 PM
GDA
Mar 17, 2003 03:20 PM
