Greddy BOV problems
Old Nov 29, 2004 | 04:04 PM
irish2ute's Avatar
Car Info: VF34, STi Injectors, Helix Up Pipe and Down pipe, Apex WS cat back, COBB AP, and Blitz FMIC
Greddy BOV problems?????
Hey Everybody-
OK....got a problem with my car dying out. Here's the scenario...when cruising on the freeway at freeway speeds and i put the car straight into neutral the car stalls out. To get it started again I have to put it into gear to start. Does anybody else have this problem. Is my BOV not adjusted correctly? This is really dangerous and i need some help. my mods are...
vf34
blitz FMIC
Greddy BOV 100% atmospheric
Greddy Airinx
Sti Injectors
Helix up/dp
Greddy Cat back
COBB VF34 Map
thanks!
Old Nov 29, 2004 | 04:48 PM
View Askew's Avatar
Car Info: '21 STI
It's a vacuum leak. Check all the hoses and make sure there are no holes or cracks in them.
Old Nov 29, 2004 | 11:42 PM
Onizuka's Avatar
Car Info: 04 STi
You might want to also try teflon tape on your Greddy. If you take off the allen screws at the top of the BOV, you can teflon a portion of it where it doesn't seal very well. I did this to my friends Greddy Type S and it worked perfect there after.
-GDO
Old Nov 30, 2004 | 12:46 AM
Jimpreza's Avatar
Car Info: truck
Just out of curiosity irish2ute, do you know what kind of numbers and times you are putting down with that setup?
Old Nov 30, 2004 | 08:03 AM
irish2ute's Avatar
View- thanks for the tip, when you say hoses are you saying the FMIC piping? because they all look good.
Onizuka- thanks I'll try that tonight
Jimpreza- I haven't put a run down yet but on dyno day at Gruppe-s I put down 230.2 hp @ 6250 rpm and 214 trq @ 5500 rpm without the FMIC, intake and BOV. I was running real lean and maxed out at 14.X psi. kinda low if you ask me.
Old Nov 30, 2004 | 04:24 PM
Onizuka's Avatar
Car Info: 04 STi
Another thing... be sure someone is around if you aren't that strong. The springs are tough to recompress.
-GDO
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
anthonyrb98
Subaru OEM Parts For Sale
Oct 26, 2005 03:25 PM
irish2ute
Dec 1, 2004 09:05 AM
jwandrews
Nov 9, 2003 02:55 PM
