Getting Away without Engine Managment?
Old Sep 25, 2003 | 06:07 PM
SJwrx's Avatar
Car Info: STi Motor Mounts, Synthetic Fluids, nothing else yet
Hey All,
VF34, Sti inject.s, and fuel pump...whats the chances I can get away wihout getting engine managment for another month and not having any damage?
Rich
Old Sep 27, 2003 | 02:13 PM
awns729's Avatar
Car Info: want a WRX
wait a month...get the tuning...
Old Sep 28, 2003 | 04:51 PM
RussB's Avatar
Car Info: $200,000 sports car
you DO need an MBC even if you're going to wait for the engine management. that turbo will boost up to 20+ psi at the drop of a hat, so be careful. I recently installed a VF34 and Up-pipe and the boost would hit 20+ Very Very quickly, then the ECU would open the wastegate and it would go down to 9psi and it would repeat that process very quickly, causing a surge effect. Use an MBC to keep the boost down about 14~15psi until you can get it tuned properly.
Old Sep 28, 2003 | 05:04 PM
SUB-ZERO's Avatar
I do not think it's going to run very well since you have the 565cc injectors and the stock programming (ecu) for the 300cc's. I faced the same problem when I installed my stg4(TXS) and wasn't able to get a laptop to load the new map. But good luck, hope everything turns out well.
-SZ
Old Sep 28, 2003 | 11:48 PM
krzyxrevver12's Avatar
Car Info: looking for a gc
drive very carefully, i have all that, i put my fmi, and intake on, im waiting for my utec before i slap the 34, injectors, and pump in.... and im kinda paranoid about it.... good luck, watch your gauges
Old Sep 28, 2003 | 11:58 PM
gpatmac's Avatar
-SZ
To elaborate on what Sub-zero said, the ECU will send a signal to your injectors to stay open for x amount of time. The STi's flow more volume than stock, so you will be much richer than if you were still on the stock injectors, or without EM. I would imagine the same could be said of the fuel pump, but I've never really read anything about that.
Old Sep 29, 2003 | 11:54 AM
RussB's Avatar
I have a vf34, MBC, up-pipe, cat back on an otherwise stock car. it runs fine at about 15 psi. going to check the A/F ratio's and injector duty cycles later this week. i'll post how it goes.
IllNastyImpreza
Sep 29, 2003 08:06 PM
Jay04WRX
Aug 9, 2003 11:07 PM
BlackDubbaUREks
Mar 21, 2003 10:59 AM
turbofreak
Dec 21, 2002 02:35 PM
Jaxx
Nov 22, 2002 04:04 PM
