Generic downpipe or problems running w/o engine mgt? (was:02 wrx questions?need help)
Old Jan 13, 2007 | 09:30 PM
solechild's Avatar
Car Info: 2002 Subaru Impreza Wrx
02 wrx questions?????need help
i have a 02 wrx im looking to put a tbe & up but i was jus wonderin if there would be any problems wit that and not runnin a accessport or anythin??? and second is there anyone that has used a generic tbe & up for there car and is there an problems that you have ran into wit the parts thanks in advance for the help....
Old Jan 13, 2007 | 10:06 PM
Superglue WRX's Avatar
No problems there. Fitment of generic parts tends to depend on generic parts being used. I personally haven't come across any bad reviews regarding up/down pipe spacing.
If you don't forsee having enough $$$ to get an AP for a while, you might want to look into getting a manual boost controler. You can find them around $80-$120, just keep it under 17psi.
Old Jan 14, 2007 | 02:43 AM
solechild's Avatar
would the parts cause boost spikes?
Old Jan 14, 2007 | 07:54 AM
Wingless Wonder's Avatar
With a manual boost controller, under certain conditions you might encounter part-throttle, full-boost and the engine may run lean as a result. Free-flowing exhaust alone may add to the leaning out but members have run exhaust without engine management with satisfactory results. I like to recommend getting engine management like the AccessPORT or EcuTek reflash at the same time as the exhaust because it makes more safe power than the exhaust without engine management, anyway.
With the stock '02 WRX turbo, I don't recommend running more than 16 psi with the 91 octane pump gas available in CA.
Old Jan 23, 2007 | 11:49 AM
damey1's Avatar
Car Info: 04' WRB Wagon
I've use an ebay (erz) uppipe before. There was no fitment issues or problems. I ended up switching it out to Helix and it ran the same. One thing I would recommend when using generic parts is to not use the gaskets that are included with the pieces. Hope that helps.
Old Jan 24, 2007 | 02:51 PM
Jake's Avatar
no problem to run stage 2 without AP but it sure does make a hell of a difference with the AP
Old Jan 29, 2007 | 11:26 PM
WRX409's Avatar
Car Info: 04 WRX
Thumbs up
The AP makes all the difference get one.
Old Feb 2, 2007 | 01:33 PM
WrxNeffects's Avatar
Car Info: 2002 platinum silver WRX
you may want to check in to cel fixes because tinkering w/exhaust parts pretty much means your going to throw a code ....maybe the 2.2 k-ohm 1/2 watt resistor trick(uppipe egt code) and the rear o2 spacer trick(catylist efficiency threshold code)
hampster92188
Jan 20, 2012 11:22 AM
supermoose
Feb 7, 2007 09:20 AM
grex767
May 27, 2006 10:37 AM
cmb
May 30, 2003 11:03 PM
