Gauges
Old Jan 1, 2013 | 03:47 PM
curtisjae21's Avatar
Gauges
I need help with knowing what I need to get to install an oil pressure gauge, air/fuel ratio gauge & a boost gauge. Can anyone give me a list of needed items?
Old Jan 1, 2013 | 03:55 PM
xhengmanx's Avatar
when you buy gauges, normally it would come with all the sensors and waht not. You can remove an oil gallery plug on the block to install the oil pressure sensor or buy a oil sandwich adapter that goes in between the oil filter and oil cooler. As far as boost gauge goes, you'll need a plastic T fitting and rubber line to route from the bpv hose to the gauge. and A/f gauge you'll need t-taps and some connectors.
Old Jan 1, 2013 | 04:09 PM
Thank you, as of now there's a connection for the boost gauge from a tube. So I was told. But thank you for the information!
So this is like few hour job to do myself?
Old Jan 1, 2013 | 04:28 PM
soybean's Avatar
Car Info: 2006 Aspen White STi
I recommend getting Fuse Taps, some molex connectors(i bought some from Fry's), and wire so you can make your own gauge wiring harness easy to expand & retract.
Old Jan 1, 2013 | 04:34 PM
What? So why do I do with the fuse taps and I'm guessing I just use the molex connectors as the wiring in between? Is this just to supply power to the gauges?
What* do I do with the fuse taps
Old Jan 1, 2013 | 07:18 PM
soybean's Avatar
Tap into your fuse box unless you want to splice into the radio/Clock harness.
Old Jan 1, 2013 | 08:26 PM
Any advice on doing that? And running the wires?
mav1c
Nov 15, 2006 10:37 AM
Hatteroo
Oct 21, 2006 12:53 PM
gruppe-s
Exterior / Interior Lighting
Jul 19, 2006 07:15 PM
gruppe-s
Jul 19, 2006 07:14 PM
gruppe-s
Vendor Group Buys/Specials
Sep 10, 2003 03:07 PM
