Fuel Pump issue?
Old Jun 22, 2008 | 02:14 AM
l burke l's Avatar
Car Info: 04 wrx wagon
what was the final fix for this so if people have this problem in the future they can track it down
Old Jul 15, 2008 | 11:33 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
yea the reason why id didn't post a fix because i wasn't too positive about it.. i thoguht it was a fix but it wasn't..i just finished covering up all the cuts i've made and nothing. I have found that once i hit a bump..it would kill the fuse.
Old Jul 15, 2008 | 11:39 AM
Egan's Avatar
That definitely sounds like a short in the wiring. You're only seeing it when a bump causes the wire to move and short out against the body of the car or some other piece of metal.
Other than the alarm and stereo are there any other electrical modifications (i.e.: Turbo Timer, Gauges, Boost Controller, etc.). Something has been tied into your ignition wire and when it shorts out it goes back to the fuse.
Old Jul 15, 2008 | 12:08 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
took off the turbo timer (HKS turbo timer), no boost controller, im using AP, as for gauges i had a OEM sti boost gauge but too it off..only thing that was connected to it was to light it up but i already checked. I Will continue to search. thanks..i'll keep update. if anyone has any other suggestion. limmie know..
Old Jul 15, 2008 | 03:14 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
alright so i patched up the wires that were exposed to install the deck and also the ecu to install the turbo timer. so i backed out my garage to hit the curb again and i thoguht it worked..well so i decided to do it again and it blew the fuse. I've found that once i hit the pump in the rear part of the car that it would blow the fuse..I looked around in the back and nothing..Does this happen if the fuel pump goes bad?
Old Jul 16, 2008 | 09:36 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
Some one told me that it could be the starter..but im not too sure on it...anything else?
Old Jul 16, 2008 | 05:03 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
here are some resources.
http://answers.yahoo.com/question/in...2085504AAc1ZQb
http://www.automotiveforums.com/vbulletin/t147178.html
http://en.allexperts.com/q/Pontiac-7...se-blowing.htm
Starter?
Old Jul 17, 2008 | 08:09 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
so i was searching around...does the ignition Relay go bad?
Old Jul 18, 2008 | 12:44 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
reset the car..and now it just blows the fuse when i try to try it on
Old Jul 18, 2008 | 06:32 AM
Egan's Avatar
Since you're in Sacramento I would suggest driving over to dbTuned in Roseville and having Paul take a look at it.
Old Jul 19, 2008 | 02:52 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
hah i'll have to find a tow truck..car doesn't even start now..just blowing the fuse.
drifter04
Nov 5, 2008 10:38 PM
iNfEk
Hawaii Classifieds
Jul 18, 2007 01:01 PM
ImprezaRSX
Feb 3, 2004 02:09 PM
JohnB
Jun 30, 2003 12:14 PM
