Fuel Injector Balancing & Blueprinting?
Old Dec 1, 2002 | 07:25 PM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
Question Fuel Injector Balancing & Blueprinting?
Anyone do this to their stock WRX injectors???
http://www.rceng.com/service.htm
"Any set of fuel injectors will benefit from RC Engineering's clean and flow service, This is even true of new injectors because the individual-injector and system-total fuel flows must be known for performance tuning purposes. It is not uncommon for a set of original equipment (OE) injectors to have an unacceptably wide range of fuel flow and it's possible to even have new injectors that do not function properly. RC's standard testing process identifies those problematic injectors."
Old Dec 1, 2002 | 09:43 PM
Mach5WRX's Avatar
Angry Dan
Originally posted by Akiata
Are you planning on making crazy mad power? If not, don't waste your money.
p@
www.achtuning.com
Why do you say that?
Old Dec 2, 2002 | 01:39 AM
hotrod's Avatar
I am thinking about it
I am considering it, but haven't decided if I can afford the extra $100.
New in the box injectors can vary in output by 6% - 8% I understand, and I've heard of as much as 15% variation as a worst case.
I have also heard of new injectors being leakers, (ie they never fully shut off, but drip a little)
If you end up with unbalanced injectors and the leanest injector ends up in the cylinder that needs the richest mixture, you end up giving away some power ( and gas milage) because you have to tune rich in all the other cylinders to keep from melting the lean cylinder.
I guess it depends on how close to the edge you want to get.
Larry
Old Dec 2, 2002 | 02:25 PM
Mach5WRX's Avatar
Angry Dan
Re: I am thinking about it
Larry
That's what I was thinking. I just want to optimize my stock ones. I'm not trying to make "mad crazy power" Just want to help the injectors out, so they don't have to work so hard. I'm sure my stock ones are close to max.
Old Dec 3, 2002 | 08:31 AM
Z1 Performance's Avatar
Huh? Optimze your stock ones? Unless you ahve been running sugar in your gas tank, theya re "optimized" from the factory. This is great for a car with 150k miles on it...and even then, its iffy, asuming the owner maintained the car and ran the proper fuel in it.
Save your money..
Adam
www.z1auto.com
Z-1 Performance
Old Dec 8, 2002 | 11:26 PM
Mach5WRX's Avatar
Angry Dan
Thanks for all the input. I'm going to look into this a little more.
WRX04WRB
Jan 28, 2011 04:40 PM
wvjnky
Jan 13, 2004 09:05 PM
JohnB
Jun 30, 2003 12:14 PM
tibor75
Mar 13, 2003 10:05 AM
jasno999
Feb 11, 2003 07:43 AM
