? Fuel Cut ?
Old May 11, 2005 | 02:13 PM
2K3WRX808's Avatar
Car Info: Sonic Yellow 03 Wrx =blitz fmic,blitz intake,turbo xs boost controller,hks ssq bov x2,apexi exhaust
? Fuel Cut ?
ever since i put in my turbo xs mbc i've been hitting fuel cut , my friend told me im running really lean & i should be running more on the rich side..........
how can i get rid of this fuel cut problem w/ out removing my mbc .
another ? is , can an air/fuel controller help me out w/ the fuel cut problem if i remap my air/fuel mixture more ritcher? ........ thanks for taking the time to read this !! ! !
tony~
Old May 11, 2005 | 02:18 PM
Nick Koan's Avatar
Car Info: Legacy GT
I know you don't want to hear it, but remove the MBC.
The best way to get an air/fuel controller is to just remap the ECU (ECUtek or Cobb Accessport) to run more boost. The remapped ECU will run higher boost, and should have the correct A/F ratio at all times. And, if you use the ECU to run more boost, you can get rid of that MBC.
Old May 11, 2005 | 02:23 PM
2K3WRX808's Avatar
i can remap my stock ecu right ? how much does it usually cost ? im just learning about this reflashing thing .......
so the remapped ecu makes the turbo produce more boost? so i dont need the mbc..........!
thanks
by the way i live in hawaii and no one does reflashes down here i have to send it somewhere in cali ...
Old May 11, 2005 | 02:50 PM
Nick Koan's Avatar
Car Info: Legacy GT
An ECUtek reflash will run ~$650 for 02/03 WRXs and ~$750 for 04+ WRXs and STis. If you don't have a local tuner, I'd look at Cobbs AccessPort software. I think its a little cheaper, and you won't have to ship your ECU to cali.
Old May 12, 2005 | 02:14 PM
2K3WRX808's Avatar
Sounds Good , Thanks For The Help !
Old May 14, 2005 | 10:14 AM
GasPipe DreameR's Avatar
Car Info: lowered blk04 with no motor
what about a vishnuperformance.com reflash
Old May 14, 2005 | 11:29 PM
2Stroke's Avatar
Car Info: 2003 WRB Wagon
Vishnu stuff is top of the line (and priced accordingly). Their products are generally excellent. Vishnu's off the shelf remaps may be a little less versatile than Cobb's in terms of what mods can be accomodated, but if you take their advice on how to use their products, you will probably have a fast car.
RU-X
Mar 12, 2007 12:45 PM
dunnojack
Nov 14, 2005 05:13 AM
silver ghost
Dec 26, 2004 07:11 PM
JohnB
Jun 30, 2003 12:14 PM
pacobeagle
Jun 16, 2003 03:10 AM
