Fuel Cut???
Old Jan 19, 2006 | 03:01 PM
PSI-PWR's Avatar
Car Info: 04STi AMS Tuned
Question Fuel Cut???
i know this may sound like a noob question, but i've never experienced it. what are the symptoms/sound of fuel cut? also if i have my utec running passive(map 0) with the FCD switch off, will this have any conciquence?
Old Jan 19, 2006 | 03:22 PM
subie OCD's Avatar
Car Info: 04 STi
Fuel cut is when you rev past redline and the ecu says "whoa too much!" and stops fuel so you dont cause damage to the motor. Just dont misshift from like 5th to 2nd, fuel cut wont help there
Old Jan 19, 2006 | 03:25 PM
PSI-PWR's Avatar
reason that i'm asking is i just installed a ported vf34, helix 660cc inj, and 255lph fuel pump with all supporting mods. and now the most boost that i can get is .04 bar. i have a utec as EM and also the TXS tuner lite. i'm running everything right now on the stock ecu cause i havn't had time to play with the TSX stage 4 map. when i get on the gas, it spools till about .04 bar then i just goes flat. help!!
Old Jan 21, 2006 | 07:20 AM
ride5000's Avatar
what do you mean by "'i'm running everything right now on the stock ecu cause i havn't had time to play with the TSX stage 4 map"?
you cant run in stock mode w/bigger injectors.
Old Jan 27, 2006 | 03:33 PM
WRX-CBR's Avatar
Car Info: 03 WRX
Your probably in limp mode. Get that tune done quick.
Old Jan 27, 2006 | 03:38 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Fuel cut occurs when you hit boost levels that ECU was not tuned for. It is a ECU safety measure to prevent overboost. When it occurs, you will feel like someone stepped on the brakes and the car will drop RPMs momentaraly.
What Subie OCD described is basic Redline, not fuel cut. Redline is actually done by cutting the spark, not fuel.
If you have all the mods you have described above but still running on stock map, your car is running very poorly. Basically get it tuned ASAP.
RU-X
Mar 12, 2007 12:45 PM
dunnojack
Nov 14, 2005 05:13 AM
silver ghost
Dec 26, 2004 07:11 PM
JohnB
Jun 30, 2003 12:14 PM
pacobeagle
Jun 16, 2003 03:10 AM
