front O2 sensor CEL help needed
Old Jul 6, 2008 | 02:08 PM
bumblebee03's Avatar
Car Info: Yellow 2003 WRX wagon, 2.0L/2.5L hybrid
I'm confused...
I'm getting error P0032,Front oxygen (A/F) sensor heater circuit high input. The manual just says to trouble shoot this by checking the ECU output voltage at pins 4&5. I've done that and they're fine. So, I erased the code and picked up a new sensor and plugged in the connector, grounded the sensor body to the car (in case that mattered), and turned on the car. Sure enough, the CEL came back on in a few seconds. I tried again after disconnecting the battery for ~15 minutes. Also, the resistance across the heater on both old and new sensor is about 1-2 Ohms.
So, what could be the deal here?
Thanks!
Old Jul 6, 2008 | 10:57 PM
wow you put up good info i wish i could help
i was going to offer an extra AF ratio sensor i have laying around
Old Jul 26, 2008 | 11:04 AM
TDQuiksilver's Avatar
Just recently went through nearly the same scenario myself. I read 1 ohm from my sensor and according to the manual I have - any resistance less than 10 ohms indicates a faulty sensor.
Old Jul 28, 2008 | 10:25 AM
I ended up taking it in to the dealer and they confirmed that the sensor was bad. Unfortunately it was also stuck! They wanted to remove the piece and put it on the bench to remove the sensor, but I passed to wait until I'm doing some upgrades and have to take stuff apart anyhow...
Peaty
May 30, 2008 09:58 AM
Impooter
Jan 3, 2005 09:59 AM
ImprezadantE
Oct 19, 2004 02:47 PM
superfly
Feb 18, 2004 09:04 PM
imprezapilot
Jan 6, 2004 10:22 PM
