Factory Boost Gauge???
Old Dec 15, 2002 | 08:22 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Actually it can be more accurately referred to as a manifold pressure gauge.
0= atmospheric pressure
below 0= vacuum
above 0= positive pressure or boost.
At idle, coasting in gear, or under light load you will see vacuum.
As you accelerate and load the engine you will see it rise from vacuum past the 0 point into positive boost.
There are conversion charts for the metric scale on the factory gauge, I don't know if any have been posted here yet but you can search for them on NASIOC.
The most important reference points for boost are .05Mpa (approx. 7psi) and .1MPa (approx. 14 psi).
Old Dec 15, 2002 | 11:26 PM
ScoobyBoy's Avatar
yup when you're not boosting you'll be in vacuum. its perfectly normal.
what i did to get used to the conversions, is to print out a cheat sheet. slapped that sucker somewhere i could see it, and used it everytime i couldnt figure how many psi's i was at.
cdawg
Jan 4, 2008 03:44 PM
WRXLR8R
Aug 27, 2003 12:59 AM
shamster
May 14, 2003 02:18 PM
mattr762
Apr 18, 2003 09:12 AM
