Exhaust Cut Out
Car Info: 2003 ASPEN WHITE WRX
Hey Guys...My Friend just gave me his brand new exhaust cut out piece and i was wondering what i needed to go along with it...like do i need up or down pipe to make it complete???
something like this?
http://www.quicktimeperformance.com/QTEC/
u have to cut and then weld it to the downpipe.
yeah its exactly like the qtec......seems koo but is getting the exhaust/ up and down pipe better performance wise? i know that installing the qtec is stealthy cuz all i gotta do is hit the switch to hide it
just wanna up date for ya'LL.....the cut out is in....and its loud as HELL....its mounted to my mid pipe and the dood took out my resonator ...so yeah imma be pulled over hella times haha....i needa get my electronics installed for it so i can close that bad boy....can anyone help me by showing me where the firewall is???? i needa install the switch to shut off the hole where the exhaust comes out now.....help me pleeeease
Car Info: My 2009 FIT for sale!!!!!!!!!!
^i saw that.... the nut was spining(spinners)! i did disconnected my cat back exhaust(the down pipe connected)...... man it sounds like a drag car and you can hear alot of turbo spool! :banana: ooo yeah i drove it around a block.... its a real head turner!
Car Info: Broken ass stock '02 WRX
bwahahaha... i cant believe they used that video, how hard would it be to tighten the nut and reshoot... makes me feel real good about buying one (if i had purchased one)
The C6 Z06 has what they call "butterfly valves" right before its mufflers...it's pretty much the same idea as this thread's concept, except it is computer controlled. For example, if it's under load and the throttle position is right, it will atomatically open up the valves allowing the exhaust gasses to bypass the mufflers, therefore creating straight pipes. I guess it's a pretty good system as it's hard to get them to open up under normal driving.
ouji
Jun 2, 2010 09:44 PM
XkrazyAsianX
Nov 9, 2005 01:02 PM
