EWG and profec b....what am I doing wrong?
I just did my UR external wastegate setup and for some reason I can't control boost with the profec b spec II, or the stock solenoid for that matter. I have the vacuum lines ran as the Greddy manual shows, but all I hear is crazy surging and the boost just keeps climbing.
When I bypass it and run it off the 1.0 bar spring it works as it supposed to though. I 'm almost positive I have the lines ran corectly. I installed the bc yesterday on my stock WG setup and it worked fine.
Any ideas?
Any ideas?
Solenoids plumb into the top port of the wastegate. boost line into the bottom.
MBCs plump into the bottom, vented top.
You'll have to completely retune the Profec B if you had it originally setup for IWG
Steve278
Nov 29, 2013 11:37 PM
verc
Mar 15, 2011 06:26 PM
BBKG79
Apr 21, 2009 04:27 AM
gesundlich
Mar 17, 2009 01:40 PM
dgp2003wrx
Apr 30, 2005 07:31 PM
