EWG and profec b....what am I doing wrong?
Old Feb 24, 2007 | 04:17 PM
stiwanabe04's Avatar
Car Info: 04 WRX
I just did my UR external wastegate setup and for some reason I can't control boost with the profec b spec II, or the stock solenoid for that matter. I have the vacuum lines ran as the Greddy manual shows, but all I hear is crazy surging and the boost just keeps climbing.
When I bypass it and run it off the 1.0 bar spring it works as it supposed to though. I 'm almost positive I have the lines ran corectly. I installed the bc yesterday on my stock WG setup and it worked fine.
Any ideas?
Old Feb 26, 2007 | 08:02 PM
testes1010's Avatar
Solenoids plumb into the top port of the wastegate. boost line into the bottom.
MBCs plump into the bottom, vented top.
You'll have to completely retune the Profec B if you had it originally setup for IWG
Steve278
Nov 29, 2013 11:37 PM
verc
Mar 15, 2011 06:26 PM
BBKG79
Apr 21, 2009 04:27 AM
gesundlich
Mar 17, 2009 01:40 PM
dgp2003wrx
Apr 30, 2005 07:31 PM
