engine "shaking"
Old Sep 25, 2006 | 01:48 PM
NEO_WRX's Avatar
engine "shaking"
I have a 2004 WRX with a few bolt ons(stock turbo). I was crusing around my friends neighborhood and hit a pretty nasty pothole at about 15 miles per hour. about 5 minutes after that i pull up to a red light and i can feel the car start to shake. It's reasonably noticeable at idle, after about 2000rpm it seems to go away. I popped the hood and you can see the motor shaking in the engine bay and definately feel it in the shifter. I'm not really sure what would cause it to act like this and was curious to see if anyone had any suggestions.
Old Sep 25, 2006 | 02:18 PM
midnitewrx02's Avatar
Car Info: 2006 CGM WRX
our motors like to wobble, its in the nature of the pistons shooting in opposite directions.. unless you went over that pothole hard enough that you damaged or broke a mount (engine or tranny)
Old Sep 25, 2006 | 02:39 PM
pwnx0rz's Avatar
Car Info: '02 WRX wagon
maybe the Weapon*R Engine Torque Dampener can't help keep the engine from shaking a bit.
Old Sep 25, 2006 | 02:40 PM
NEO_WRX's Avatar
ya, i understand they like to rattle a little bit. I've owned the car for nearly 3 years now. This is a SHAKE. You can actually feel the car wobble and the shift **** is moving in place. I hear a very slight ticking sound, but i think that might be the FMIC piping tapping onto the raditor fan bracket(i had to cut it make the pipe fit..and it's a pretty tight fit). Would the motor shaking be a sign of internal damage? I just get pretty paranoid when things aren't going right.
Old Sep 25, 2006 | 04:26 PM
Superglue WRX's Avatar
Sounds like it's time to replace your motor mounts. I can't think of anything else that would cause exactly what you described.
fenderstrat066's Avatar
Car Info: 2004 Wrx
+1 bad motor mounts....
Old Sep 26, 2006 | 12:32 PM
NEO_WRX's Avatar
well it was actually a mis-fire in cylinder # 3.
the pot-hole jostled the plug wire clip out of the coil pack by just a little bit. So upon first inspection it looked like it was in securely but after i took it off and re-inserted it everything smoothed out.
thanks everyone.
Old Sep 26, 2006 | 04:57 PM
thanks everyone.
I assumed the car was running fine and the engine was just twisting on the mounts. I don't see how a misfire on a 4 cylinder wasn't noticible after 2K rpms?
Glad everything is fine now
SFGatdula
Sep 7, 2013 11:50 PM
kimchijeegeah
Aug 5, 2011 05:24 AM
wrx360
May 13, 2003 11:27 AM
QuickShift
Feb 10, 2003 04:54 PM
Hollandaze
Dec 3, 2002 07:25 PM
