Engine Seal Replacement
I've been trying to prepare to change my timing belt out for a while now. Trying to obtain the right tools...etc. Since I'm in that area, I'm looking into replacing a couple of seals that are probably bad and need replacing.
For those that have changed the timing belt... have you changed out any of the seals (ie. Oil pump seal, water pump seal, camshaft seal)?
If so what did you use to remove the seals and what did you use to install them? I'm looking for a way to install it correctly and not to damage it while installing it.
Jon
Jon
kidatari
Sep 20, 2004 06:47 PM
corsairius
Jan 22, 2003 09:03 AM
