Rear Transmission Seal Leak
Old Mar 8, 2003 | 01:11 AM
WRX151's Avatar
Guys, anyone do a clutch and flywheel upgrade have problems with the rear seal leaking? Let me know. I could use some help.
Mahalo,
Larry
Old Mar 8, 2003 | 12:46 PM
Chibby Goku's Avatar
Car Info: Vakamon WRX
Just a suggestion
If you don't have obvious warranty voiding mods, bring your car to Schuman Waipahu and see Ed (sub-sonic).
Old Mar 8, 2003 | 01:37 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
The rear seal would leak if during the clutch install, the seal was damaged. When you do clutch install, you need to pull the driveshaft out and then put it back in. So, more than likely when that was done, the seal was pinched, poked, nibbled on, etc.
Who did your clutch install?
- Alex
ckolbash
Aug 10, 2013 03:00 PM
NorCal_Scoob
Aug 20, 2012 04:15 PM
iNfEk
Dec 18, 2004 10:37 PM
bigdaddy
Jul 10, 2003 12:09 PM
WRX151
Mar 8, 2003 01:09 AM
