Engine Noise
Old Feb 26, 2008 | 08:49 AM
unstble's Avatar
Car Info: WREX
This is a very common failure.
I've repaired some with as few as 37k miles.
One was so bad, it destroyed the timing belt.
Paul - thanks for the reply!
Is there anything else to replace besides the small tensioner/pulley/bearing?
What I did was, remove the shrapnel (metal shavings and lingering pieces), remove the hollowed-out tensioner = looks like an open socket at this point, then removed the bolt.
I then just applied pressure to the belt (with my hand) just enough to start threading the new tensioner in place; however, it seemed like the bolt was too long when installing with the new tensioner (bolt would not tighten any further and the tensioner would move side-to-side a bit ~1/8-1/4 inch of space between block and tensioner pin) so I used a couple of washers to take up the space.
A question i have is this, Is there a piece that I may be missing, which may have been destroyed when the original tensioner fell apart?
Is there a picture or diagram of the actual part(s) that go to this one location?
This is really driving me
Old Feb 26, 2008 | 01:03 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
The new & updated roller requires a new bolt; contact your local dealer.
Old Feb 26, 2008 | 01:59 PM
unstble's Avatar
Car Info: WREX
I just called and was told the the bolt is the 808208320 bolt - $2.85?
Is this the correct bolt part number?
Btw: what's the benefit of using a new bolt versus using the old bolt?
Old Feb 29, 2008 | 08:47 PM
emerick's Avatar
Car Info: 04 wrx
unstble, i have a similar noise coming from the d-side too. im pretty sure its something to do with the power steering when i cold start, i hear it when i turn the steering wheel, and sometimes at a stop light. when i gas it goes away... i tore everything apart and it all looks good... so im stumped... i tried the broom thing too... i ended up slapping myself with the broom.. bAH.
Old Feb 29, 2008 | 09:51 PM
unstble's Avatar
Car Info: WREX
The noise I have is always audible (not just when turning) and yes, I do hear it at the stop lights, when the car is idle, and the rumble of the exhaust does not interfere with hearing the strange noise.
When you say you "i tore everything apart" does that mean that you removed all the plastic pieces covering the timing belt, which would include having to remove the crank pulley?
I have heard of someone else having a similar noise, and it ended up being an internal engine issue......$$$ But, if you are hearing this when turning, perhaps it could be a split CV boot and your shafts are drying and rubbing causing metal-to-metal contact? This would definitely cause a strange noise to occur!
Old Feb 29, 2008 | 09:53 PM
unstble's Avatar
Car Info: WREX
On another note.........I just went to another Subaru dealer, and found out that the first dealership sold me the wrong item! This part number doesn't even belong on MY05. Now I have to go back and exchange the part.....at the least the dealership was cool about doing a straight exchange.
Old Feb 29, 2008 | 10:24 PM
sabrebluewhale's Avatar
Car Info: '04 WRX
That sounds like AC belt
I had that happen at a little after 60,000 on my '04 WRX and installed new accessory belts and don't hear it anymore. It sounds like your power steering belt is just slipping. How many miles are on your car?
Old Mar 1, 2008 | 08:04 AM
unstble's Avatar
Car Info: WREX
To find out if it's a belt, simply remove the two accessory belts, start the car and see if the noise is still there....if not, then it's a belt issue.
Belts are ~$15 at Kragen and take about 20 minutes to replace.
Old Mar 1, 2008 | 05:54 PM
emerick's Avatar
Car Info: 04 wrx
Talking
thanks dude I'll ty it. I currently just hit 60xxx miles. Synth oil change. So I'm good with internals. I'll change the belts anyways bcause its time.
Old Mar 16, 2008 | 09:39 PM
strider327's Avatar
Car Info: 2005 WRX
I also recently started having a weird "clanking" noise. Although it does not sound as severe as most of yours. Its very faint and can kinda only be heard at idle but at a very very low volume. I cannot really pinpoint to where it is coming from but its definitely there. If need to take a guess, its somewhere around the IC area or the intake manifold area in general. I don't know what it is exactly, but I've kept up to date with all service work. I got all fluids, spark plug, and even the timing belt done. I have not changed the a/c belt or the alternator belt as of yet. Like I said it is very very faint at idle. Even when the hood is open I can barely hear it, but it is there.
Old Mar 24, 2008 | 11:24 AM
unstble's Avatar
Car Info: WREX
Update......I just finished my Gates timing belt install....started up the car and it runs smooth
The job was much easier than I made it out to be....will be much faster a second time, it it comes around again.
Old Mar 31, 2008 | 04:56 PM
wrx'd's Avatar
Car Info: 03 WRX
I just got off work, and went to go listen to the noise again, with a friend this time, and we concluded that the noise is coming from the AC Compressor.
Has anyone else had an issue with their AC Compressor dying so soon - 50k
miles?
try oiling the belts and the clutch on the ac compressor ,
mine was doing the same thing, chirping, and rattling noise,
ended up just needing oil,,
never had another prob!
all yall with these minor noise prob's ...
they shouldnt be anything to worry about , be be cautious
this happend to me again when i did my TMIC swap, the IC was just barely moving and rattliing against the ac line against the fire wall ( use pipe insulation to protect to solve the prob )
Old Apr 1, 2008 | 08:52 AM
unstble's Avatar
Car Info: WREX
Actually, these noises should worry you, as my engine noise turned out to be a defective tensioner pulley and was just barely in place due to the plastic timing belt cover holding it on the bolt. This issue also caused the timing belt to get chewed up from all the shrapnel from the tensioner pulley parts that fell apart.
So, please, do be concerned when hearing any noises coming from the car that are not normal.
Old May 6, 2008 | 09:58 AM
tofuman's Avatar
Car Info: a blue car
unstble, were you able to fix the problem with the new belt/tensioner? I'm at 50k and wondering if I should be replacing my T belt and tensioner as well. SoA online maintenence says 105,000 is the recommended replacement interval.
Paul, is this for certain years or motors (2.0L, 2.5L, FI, NA) that you've seen this on or is it pretty much across the board for most recent subaru models.
CFar
Dec 8, 2003 04:19 PM
impreza_wrx09
Dec 3, 2003 09:50 PM
3RdT
Nov 10, 2003 03:30 PM
VitaminWRX
Nov 1, 2003 12:58 AM
igorshos
Mar 6, 2003 08:25 AM
