Engine Misfire! Compression Results!
Old Jan 1, 2007 | 08:39 PM
spoolinwrx's Avatar
Car Info: 02 WRB WRX Sedan
nevermind
all fixed
Old Jan 1, 2007 | 10:02 PM
SubyN00by's Avatar
cyl 1 is fux0red...
Old Jan 1, 2007 | 10:05 PM
whitecel's Avatar
Car Info: 2005 WRX
can't remember but doesn't white smoke mean coolant is being burned?
Old Jan 1, 2007 | 10:15 PM
SubyN00by's Avatar
cylinder wall crack perhaps...
Old Jan 2, 2007 | 09:40 AM
you cross threaded teh plug
head gasket leaking
you put the gague in wrong and thats why you didnt get a reading
you should have gotten something
in what order did you test tehm ?
Old Jan 2, 2007 | 10:26 AM
spoolinwrx's Avatar
head gasket leaking
1-2-3-4
Old Jan 18, 2007 | 07:58 PM
nautic1601's Avatar
Car Info: 2000 Subaru Impreza 2.5 RS
possibly a bent/dropped valve
if the valve was bent it would bleed off pressure, but still should read something? could also explain white smoke, but I also think that white is coolant. blue for oil, black for fuel and white for coolant if I remeber correctly? Any mixing of oil/coolant that may suggest head/head gasket leak?
Old Jan 28, 2007 | 06:50 AM
ride5000's Avatar
headgasket or hole in piston (not cracked ring land) or bent valve. is there coolant in the oil or oil in the coolant? do a leakdown test and listen for where the leak is.
Mautai916
Jan 7, 2011 05:30 PM
sc0013z
Jun 11, 2007 07:33 AM
nytoy
Oct 13, 2004 06:20 AM
WRXYBOY
Jul 24, 2004 11:43 AM
rash
May 17, 2003 12:32 PM
